[Swift-user] Fwd: get error when try to set swiftworkdirectory to /gpfs
Yi Zhu yizhu at cs.uchicago.edu
Thu Mar 18 16:47:13 CDT 2010
Hi
I think I've found the reason of error, by using direct address rather
than linked address, the error disappeared.
e.g. instead of set the directory address:
"/gpfs/ci/swift/yizhu/swiftwork", i use
"/autonfs/gpfs-pads/projects/CI-CCR000013/yizhu/swiftwork", and then
everything works fine.
-Yi
-------- Original Message --------
Subject: 	get error when try to set swiftworkdirectory to /gpfs
Date: 	Thu, 18 Mar 2010 12:21:19 -0500
To: 	swift-user at ci.uchicago.edu
I have a problem after switch my swift working directory from /home/ to
/gpfs
My jobs was running on PADS, and my input data was stored at /gpfs and
the swift work directory was set to /home/swiftwork and everything works
fine.  But when I change my swift working directory from
/home/yizhu/swiftwork ( in sites.xml) to /gpfs/ci/swift/yizhu, i got
lots of job failure( about half of them failed).
since /gpfs/ is also a shared file system and should be transparent for
swift, I have no idea why this happened.
-Yi Zhu
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100318/de7dd076/attachment.html>
More information about the Swift-user mailing list
