[Swift-user] Re: Error with condor provider
Arjun Comar
mandaya at rose-hulman.edu
Wed Jun 23 17:21:34 CDT 2010
Alright, so I just tried again with trunk over Mike's stable repository and
it worked, so it looks like whatever the problem was got fixed between
stable and trunk. However submitting jobs to condor results in the job
simply getting held. Do I need any permissions over grid-proxy-init? Same
thing happens when I run condor_submit on the command line.
Condor submit file:
executable=/bin/echo
arguments=Hello World!
output=results.output
error=results.error
log=results.log
notification=never
universe=grid
grid_resource=gt2 gsu1.uchicago.edu/jobmanager-fork
queue
and I submitted with:
condor_submit myjob.submit
results in:
-- Submitter: bridled.ci.uchicago.edu : <128.135.125.18:49572> :
ID OWNER SUBMITTED RUN_TIME ST PRI SIZE CMD
57.0 aespinosa 6/15 11:54 0+00:00:00 I 0 7.3 condor_dagman
71.0 arjun 6/23 11:24 0+00:00:00 H 0 0.0 echo Hello
World!
72.0 arjun 6/23 17:05 0+00:00:00 H 0 1.0 bash
/opt/osg/data
3 jobs; 1 idle, 0 running, 2 held
(My first job is the condor-submit job, the second is the job I attempted to
submit via swift.)
Any thoughts?
Arjun
On Wed, Jun 23, 2010 at 11:26 AM, Arjun Comar <mandaya at rose-hulman.edu>wrote:
> Hey all,
> I've been trying to get jobs submitted over Condor via swift, and running
> into a few problems. I think I've finally hit a point where it's the Condor
> provider itself that's failing over any of my configurations.
> Here's the sites entry (though any sites entry over Condor will do, and
> I've tried several):
> <config>
> <pool handle="Nebraska_red.unl.edu">
> <gridftp url="gsiftp://red.unl.edu/"/>
> <execution provider="condor"/>
> <profile key="jobType" namespace="globus">grid</profile>
> <profile key="gridResource" namespace="globus">gt2
> red.unl.edu/jobmanager-condor</profile>
> <workdirectory>/opt/osg/data/engage/tmp/red.unl.edu</workdirectory>
> </pool>
> </config>
> And any swift script at all fails, even a simple helloworld:
> type messagefile;
> app (messagefile t) greeting () {
> echo "Hello, world!" stdout=@filename(t);
> messagefile outfile <"hello.txt">;
> outfile = greeting();
> With the following error:
> The following errors have occurred:
> 1. Application "echo" failed (Cannot submit job: Could not submit job
> (condor_submit reported an exit code of 1). Submitting job(s)
> Found illegal unescaped double-quote: "" -e /bin/echo -out hello.txt -err
> stderr.txt -i -d "" -if "" -of hello.txt -k "" -status "provider " -a
> "Hello, world!"The full arguments you specified were:
> red.unl.edu/helloworld-20100623-1051-dr5v5apa/shared/_swiftwrapecho-dqt6jttj -jobdir d -scratch "" -e /bin/echo -out hello.txt -err
> "Hello, world!")
> The same script runs just fine through any other submission mechanism, even
> to the same site (ssh, coasters+ssh:pbs, etc).
> Anyone have any thoughts on fixing the problem?
> Thanks!
> Arjun Comar, Rose-Hulman '12
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100623/ab27cdfd/attachment.html>
More information about the Swift-user
