[Swift-user] Compile Error
Jonathan Monette
jon.monette at gmail.com
Tue Jun 22 15:37:51 CDT 2010
Alright, was not sure. Yea. That is when it failed.
On 6/22/10 3:35 PM, Mihael Hategan wrote:
> If it failed at compile time then it doesn't matter.
> On Tue, 2010-06-22 at 15:32 -0500, Jonathan Monette wrote:
>> Also, the script was run on my macbook as localhost. Was not run using
>> coasters or anything of that sort.
>> On 6/22/10 3:13 PM, Mihael Hategan wrote:
>>> I may have sent this before, but I think it's useful reading. Don't take
>>> it as meant to be patronizing. It's meant to clarify the perspective of
>>> the other end of a bug report.
>>> http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
>>> On Tue, 2010-06-22 at 15:04 -0500, Mihael Hategan wrote:
>>>> I thought I replied to it, but is seems not.
>>>> Yes, please post the exact script.
>>>> Mihael
>>>> On Tue, 2010-06-22 at 15:00 -0500, Michael Wilde wrote:
>>>>> Jon, can you try to re-create this problem in a simple Swift script?
>>>>> If so, Mihael, can you take a look and see if its a Swift error, and/or how to work around it?
>>>>> Thanks,
>>>>> Mike
>>>>> ----- "Jonathan Monette"<jon.monette at gmail.com> wrote:
>>>>>> Hello,
>>>>>> I am getting a compile error and not sure how to fix it.
>>>>>> Could not start execution.
>>>>>> Compile error in foreach statement at line 81: Type
>>>>>> DiffStruct is not defined.
>>>>>> I understand the error but I have defined DiffStruct at the top
>>>>>> of
>>>>>> the file.
>>>>>> type DiffStruct
>>>>>> int cntl1;
>>>>>> int cntl2;
>>>>>> Image plus;
>>>>>> Image minus;
>>>>>> Image diff;
>>>>>> I have also declared Image as a type. Using Image gives me no
>>>>>> problems. The line that the error comes on is:
>>>>>> foreach diff_entry, i in diffs
>>>>>> where diffs is an array of DiffStruct that was created using the
>>>>>> csv_mapper. Does anyone know what the problem is? Thanks in
>>>>>> advance.
>>>>>> Jon
>>>>>> Computers are incredibly fast, accurate, and stupid. Human beings are
>>>>>> incredibly slow, inaccurate, and brilliant. Together they are powerful
>>>>>> beyond imagination.
>>>>>> - Albert Einstein
>>>>>> _______________________________________________
>>>>>> Swift-user mailing list
>>>>>> Swift-user at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user
