[Swift-user] Compile Error
Jonathan Monette
jon.monette at gmail.com
Tue Jun 22 15:22:04 CDT 2010
Here is a script that recreates the problem and the two files needed to
run. The line commented out is the Montage call but the error comes
before the call.
On 6/22/10 3:13 PM, Mihael Hategan wrote:
> I may have sent this before, but I think it's useful reading. Don't take
> it as meant to be patronizing. It's meant to clarify the perspective of
> the other end of a bug report.
> http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
> On Tue, 2010-06-22 at 15:04 -0500, Mihael Hategan wrote:
>> I thought I replied to it, but is seems not.
>> Yes, please post the exact script.
>> Mihael
>> On Tue, 2010-06-22 at 15:00 -0500, Michael Wilde wrote:
>>> Jon, can you try to re-create this problem in a simple Swift script?
>>> If so, Mihael, can you take a look and see if its a Swift error, and/or how to work around it?
>>> Thanks,
>>> Mike
>>> ----- "Jonathan Monette"<jon.monette at gmail.com> wrote:
>>>> Hello,
>>>> I am getting a compile error and not sure how to fix it.
>>>> Could not start execution.
>>>> Compile error in foreach statement at line 81: Type
>>>> DiffStruct is not defined.
>>>> I understand the error but I have defined DiffStruct at the top
>>>> of
>>>> the file.
>>>> type DiffStruct
>>>> int cntl1;
>>>> int cntl2;
>>>> Image plus;
>>>> Image minus;
>>>> Image diff;
>>>> I have also declared Image as a type. Using Image gives me no
>>>> problems. The line that the error comes on is:
>>>> foreach diff_entry, i in diffs
>>>> where diffs is an array of DiffStruct that was created using the
>>>> csv_mapper. Does anyone know what the problem is? Thanks in
>>>> advance.
>>>> Jon
>>>> Computers are incredibly fast, accurate, and stupid. Human beings are
>>>> incredibly slow, inaccurate, and brilliant. Together they are powerful
>>>> beyond imagination.
>>>> - Albert Einstein
>>>> _______________________________________________
>>>> Swift-user mailing list
>>>> Swift-user at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100622/a224ffa2/attachment.ksh>
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100622/a224ffa2/attachment-0001.ksh>
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100622/a224ffa2/attachment-0002.ksh>
More information about the Swift-user
