[Swift-user] first.swift
Michael Wilde
wilde at mcs.anl.gov
Thu Jan 28 05:40:17 CST 2010
Jamal, were you asking whether you can avoid using "mappers"
(which are indicated by <>) or whether you can avoid using
the chars "<>" in a Swift script?
In either case, I believe the answer is "no", in that Swift
is based on the use of mappers, and the syntax for mappers
requires "<>".
- Mike
----- Original Message -----
To: "J A" <jamalphd at gmail.com>
Cc: swift-user at ci.uchicago.edu
Sent: Wednesday, January 27, 2010 4:02:22 AM GMT -06:00 US/Canada Central
Subject: Re: [Swift-user] first.swift
> Is there a way to avoid using the '<' and '>' in the script and have code
> still do the same thing?
This is the kind of question that makes me reply with "why are you asking
that?" ;)
so:
why are you asking that? (why do you not want < and > in the script?)
Swift-user mailing list
Swift-user at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
