[Swift-user] unmapping a file
Michael Wilde
wilde at mcs.anl.gov
Fri Jan 22 15:49:21 CST 2010
There is no way to unmap a variable.
And you need to manually ensure that you dont map the same physical
filename to multiple *output* variables, as then its very likely that
Swift will complain at run time that its trying to map and access a file
that is already mapped to another variable (it complains of a "cache"
conflict in such cases, as the file is already in a site's file cache).
Swift does let you map the same filename for *input* to different
variables or array members.
If a file is already mapped to a variable, one will often reference that
same variable in a later statement to re-read the same file again, or to
read a previously produced file.
But in this example, the purpose of returning a list of tile filenames
from analyzelanduse.sh was so that you can read in this list and use it
to re-map a *subset* of a previously mapped array of files.
- Mike
On 1/22/10 2:45 PM, Antonius Sardjito wrote:
> Hi,
> Is there a way to unmap a variable from a file ?
> say f----> f.txt are there ways to unmap this so I could have say
> s--->f.txt
> Thanks
> -Antonius
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
