[Swift-user] regexp problem
Michael Wilde wilde at mcs.anl.gov
Fri Jan 22 12:40:16 CST 2010
You need to specify a string pattern which has at least one matching
"parenthesized group", as below.
- Mike
$ cat strcut.swift
string output0 = "/home/wilde/bigdata/data/modis/output/mydir/my.file";
string pattern = "/home/wilde/bigdata/data/modis/output/(.*)";
string cutresult = @strcut(output0,pattern);
trace("output0",output0);
trace("cutresult",cutresult);login2$
$ swift strcut.swift
Swift svn swift-r3202 cog-r2683
RunID: 20100122-1236-euf2lr6b
Progress:
SwiftScript trace: output0,
SwiftScript trace: cutresult, mydir/my.file
On 1/22/10 9:59 AM, Antonius Sardjito wrote:
> Hi Dr. Wilde,
> I am able to readData from the input now, into an array of string.  I am
> currently trying to use the strcut and strcat to cut the ".tif" and
> replace it with "Colored.tif"
> I tried to do something like this:
> string cutresult =
> @strcut(output[0],"/home/wilde/bigdata/data/modis/output/");
> #outfile = eccho(output[0]);
> trace(output[0]);
> and the error is :
> RunID: 20100122-0951-345qqi15
> Progress:
> SwiftScript trace: /home/wilde/bigdata/data/modis/output/h11v05.tif
> Execution failed:
>         java.lang.IndexOutOfBoundsException: No group 1
> I don't understand why I got the error IndexOutOfBounds, I have checked
> the string using a procedure that echo the string to a file, and as you
> can see from above I also checked it with trace(output[0]) which
> produces a valid value.
> -Antonius
> ps.
> This is the whole test file named mini.swift
> type file;
> file input <"input_for_mini_test.txt">;
> string output[] = readData(input);
> file outfile <"output_for_mini_test.txt">;
> string color = "Colored.tif";
> app (file out) eccho (string inputStr)
>         echo inputStr stdout=@out;
> string cutresult =
> trace(output[0]);
> --EOF--
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
