[Swift-user] Coaster jobs are not running with expected parallelism
Michael Wilde wilde at mcs.anl.gov
Tue Jan 19 14:23:43 CST 2010
With workersPerNode = 8, I now see 2 PBS jobs; one has 1 node, one has 3
nodes.
Now *16* jobs are active.
The pattern seems to be that its only running workersPerNode app() tasks
per PBS job (ie, per block).
I'll see if I can get it to run workersPerNode tasks per *node* with
more explicit settings in the sites file.
The current jobs is:
/home/wilde/protlib2/bin/run.loops.sh: Executing on site pbs
Running from host with compute-node reachable address of 172.5.86.6
Running in /home/wilde/protests/run.loops.5357
protlib2 home is /home/wilde/protlib2
Swift svn swift-r3202 cog-r2682
RunID: 20100119-1414-q09uz2c0
Progress:
Progress:  Checking status:1
Progress:  Selecting site:18  Initializing site shared directory:1
Stage in:1  Finished successfully:1
Progress:  Stage in:19  Submitting:1  Finished successfully:1
Progress:  Submitted:19  Active:1  Finished successfully:1
Progress:  Submitted:11  Active:9  Finished successfully:1
Progress:  Submitted:7  Active:13  Finished successfully:1
Progress:  Submitted:4  Active:16  Finished successfully:1
PBS says:
login2$ qstat -n
svc.pads.ci.uchicago.edu:
   Req'd  Req'd   Elap
Job ID               Username Queue    Jobname          SessID NDS   TSK
Memory Time  S Time
917.svc.pads.ci.     wilde    extended null              16709     1  --
    --  00:29 R 00:04
    c19
918.svc.pads.ci.     wilde    extended null              15309     3  --
    --  00:29 R 00:04
    c46+c45+c44
login2$
Swift log is in:
login2$ ls -l $(pwd)/*0.log
-rw-r--r-- 1 wilde ci-users 386242 Jan 19 14:21
/home/wilde/protests/run.loops.5357/psim.loops-20100119
4-q09uz2c0.log
login2$
On 1/19/10 2:09 PM, Mihael Hategan wrote:
> On Tue, 2010-01-19 at 14:02 -0600, Michael Wilde wrote:
>> -rw-r--r-- 1 wilde ci-users 912946 Jan 19 13:49
>> /home/wilde/protests/run.loops.1498/psim.loops-20100119-1309-l72sbpg8.log
>> I killed the run and will retry with workersPerNode corrected; maybe you
>> can see, though, in this log, why the run was limited to only 3 active
>> at once.
>> I'll see if same happens with workersPerNode set.
>> This would be explained if leaving workersPerNode *not* set somehow
>> defaults to 1 worker per *block* (ie per pbs job) instead of 1 worker
>> per node. Could that be hapenning?
> Not intentionally.
More information about the Swift-user mailing list
