[Swift-user] Problem staging out from PBS?
Michael Wilde
wilde at mcs.anl.gov
Tue Jan 19 12:22:34 CST 2010
I'm getting the messages below in email from PBS on pads.ci.uchicago.edu.
Are the messages:
"Unable to copy file 908.svc.pads.ci.uchicago.edu.OU to
wilde at login2.pads.ci.uchicago.edu:/home/wilde/.globus/scripts/PBS5898136727049685871.submit.stdout"
due to Swift errors (ie, somehow PBS cant write to my scripts/
directory) or due to some problem in PBS?
The prior PBS error of being unable to write to /gpfs/scratch seems to
have gone away.
- Mike
-------- Original Message --------
Subject: PBS JOB 908.svc.pads.ci.uchicago.edu
Date: Tue, 19 Jan 2010 12:16:37 -0600 (CST)
To: wilde at ci.uchicago.edu
PBS Job Id: 908.svc.pads.ci.uchicago.edu
Job Name: null
Exec host: c19.pads.ci.uchicago.edu/0
An error has occurred processing your job, see below.
request to copy stageout files failed on node
'c19.pads.ci.uchicago.edu/0' for job 908.svc.pads.ci.uchicago.edu
>>> error from copy
LD_LIBRARY_PATH=
>>> end error output
Unable to copy file 908.svc.pads.ci.uchicago.edu.ER to
wilde at login2.pads.ci.uchicago.edu:/home/wilde/.globus/scripts/PBS5898136727049685871.submit.stderr
>>> error from copy
LD_LIBRARY_PATH=
>>> end error output
More information about the Swift-user
