[Swift-user] Tuning parameters of coaster execution
Andriy Fedorov
fedorov at bwh.harvard.edu
Tue Jan 19 09:38:45 CST 2010
Hi Mihael,
I've been playing with this following your suggestions, but I can't
get it to work.
Here's my site description:
<pool handle="Abe-GT2-coasters">
<gridftp url="local://localhost" />
<execution provider="coaster" jobmanager="gt2:gt2:pbs"
url="grid-abe.ncsa.teragrid.org"/>
<workdirectory>/u/ac/fedorov/scratch-global/scratch</workdirectory>
<profile namespace="karajan" key="jobThrottle">2.55</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<profile namespace="globus" key="nodeGranularity">10</profile>
<profile namespace="globus" key="remoteMonitorEnabled">false</profile>
<profile namespace="globus" key="parallelism">0.1</profile>
<profile namespace="globus" key="workersPerNode">2</profile>
<profile namespace="globus" key="highOverallocation">10</profile>
</pool>
My maxWalltime for the job is 2, and I have 100 of them. When I run
the script, I see one job in the queue, with 10 nodes and 22 minutes
walltime. However, when the script is executing, it appears the jobs
are being scheduled one at a time. I have the current checkout of the
cog/swift trunk: Swift svn swift-r3202 cog-r2682. I attach the
coaster.log file for your reference.
Can you help me understand what I am doing wrong?
Also, I was trying to look in the code that does allocation, and it
seems that the code responsible for determining the block size for
allocation is in
modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/BlockQueueProcessor.java.
Is this correct? And what is the piece of code that decides how to
schedule jobs within the allocated block?
I would appreciate any help. Thank you.
Andriy Fedorov, Ph.D.
Research Fellow
Brigham and Women's Hospital
Harvard Medical School
75 Francis Street
Boston, MA 02115 USA
On Tue, Oct 20, 2009 at 11:23, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Tue, 2009-10-20 at 12:04 -0400, Andriy Fedorov wrote:
>> On Tue, Oct 20, 2009 at 11:55, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>> > You need a more recent version of the code.
>> Mihael, I actually updated svn for both cog and swift yesterday prior
>> to running the tests. Here's what swift reports I have right now:
>> Swift svn swift-r3170 cog-r2529
> Given that even when you have granularity=10 you still see 2 jobs, I
> suspect you are using swift site throttling parameters that force that.
> I would set the jobThrottle higher and possibly the initial score
> higher.
> For troubleshooting, what you could do is, on the remote side, say cat
> ~/.globus/coasters/coasters.log|grep "BlockQueueProcessor">bqp.log and
> post that. Also, you could set the remoteMonitorEnabled profile to
> "true" to get visual feedback of what's happening.
> The allocation time is 18 minutes because the new stuff doesn't
> overallocate using a fixed multiplier (though you can force it to do
> so). For small jobs (walltime = 1s) the multiplier is set by
> lowOverallocation (10.0 by default) while for large jobs (walltime ->
> +inf) the multiplier is 1, with an exponential decay in-between.
> If you want to always have blocks being 10 times the job walltime, you
> can set highOverallocation to 10.
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100119/99d0de37/attachment.bin>
More information about the Swift-user
