[Swift-user] Re: [Swift-devel] Problem with iterate
Ioan Raicu
iraicu at eecs.northwestern.edu
Thu Feb 18 17:10:35 CST 2010
But I don't get it, how can the variable b not have a value, if it is
consumed by cat() in a prior statement? I thought Swift followed a
write-once read many paradigm, which was enforced by the single
assignment paradigm. Perhaps it doesn't, and it was just my naive
interpretation. I guess there is a distinction between files and
variables? The single assignment only relates to variables, and not
files? I am a bit confused I think, but I am sure it will all become
clear, with a bit more explanation from you about how the single
assignment fits into SwiftScript.
Ioan
Ioan Raicu, Ph.D.
NSF/CRA Computing Innovation Fellow
Center for Ultra-scale Computing and Information Security (CUCIS)
Department of Electrical Engineering and Computer Science
Northwestern University
2145 Sheridan Rd, Tech M384
Evanston, IL 60208-3118
Cel: 1-847-722-0876
Tel: 1-847-491-8163
Email: iraicu at eecs.northwestern.edu
Web: http://www.eecs.northwestern.edu/~iraicu/
https://wiki.cucis.eecs.northwestern.edu/
Mihael Hategan wrote:
> There is no existing value of b.
> Here's the full example, which you can try out:
> app (file y) cat(file x) {
> cat @x stdout=@y;
> type file;
> file a;
> file b;
> a = cat(b);
> b = cat(a);
> On Thu, 2010-02-18 at 16:17 -0600, Ioan Raicu wrote:
>> But wouldn't the single assignment part prevent your example from
>> dead-locking? In other words, the compiler should throw an error on
>> line "b = cat(a)" as its trying to modify an existing value b.
>>> On Thu, 2010-02-18 at 17:08 +0000, Ben Clifford wrote:
>>>>> I'm unsure. I have a feeling that static dealdock detection is
>>>>> undecidable in swift. I need to think some more about that.
>>>> I think doing it statically (i.e. at compile time) is equivalent to
>>>> executing the code (including external apps) - I think there's probably a
>>>> straightforward example where something depends on an integer read from an
>>>> externally executed app which then influences an if statement that decides
>>>> which of two different arrays is being written to; or something like that.
>>> Right. So termination is undecidable by virtue of it being a turing
>>> complete language. What I'm unsure is whether deadlocks follow as a
>>> consequence of that. They are a different beast.
>>> We can probably start with simpler things. The following deadlocks with
>>> the current swift:
>>> a = cat(b);
>>> b = cat(a);
>>> So it seems that loops in the graph will create a deadlock and detecting
>>> loops requires knowing the graph. We can probably detect the static
>>> parts and we may be able to handle alternatives by issuing warnings of
>>> the "branch 1 in that 'if' combined with branch 2 in that other 'if'
>>> leads to a deadlock" sort.
>>> Arrays may be a bit tougher.
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> Ioan Raicu, Ph.D.
>> Cel: 1-847-722-0876
>> Tel: 1-847-491-8163
More information about the Swift-user
