[Swift-user] swift returns error on pads
Zhao Zhang zhaozhang at uchicago.edu
Sun Feb 28 10:38:29 CST 2010
Hi, Mihael
It worked. But it only worked if I set the "maxnodes" to "2", does that
mean "2" is the only number of
compute nodes that I could use on pads? Thanks.
Best
zhao
[zzhang at login2 final]$ cat pbs.xml
<config>
  <pool handle="pbs">
    <execution provider="coaster" url="none" jobManager="local:pbs"/>
    <profile namespace="globus" key="maxwalltime">00:00:10</profile>
    <profile namespace="globus" key="maxtime">1800</profile>
    <profile namespace="globus" key="workersPerNode">8</profile>
    <profile namespace="globus" key="maxnodes">2</profile>
    <profile namespace="karajan" key="initialScore">1000</profile>
    <profile namespace="karajan" key="jobThrottle">.63</profile>
    <gridftp  url="local://localhost" />
    <workdirectory >/home/zzhang/swiftwork</workdirectory>
  </pool>
</config>
Mihael Hategan wrote:
> The poor thing is allocating more nodes than are available. Specify
> maxnodes.
> On Sun, 2010-02-28 at 00:45 -0600, Zhao Zhang wrote:
>> Thanks, Allan. But I still got the same error.
>> zhao
>> Allan Espinosa wrote:
>>> I think it should be workersPerNode
>>> On Sun, Feb 28, 2010 at 12:08:12AM -0600, Zhao Zhang wrote:
>>>> Hi,
>>>> I have a following error message from swift when I ran it on pads
>>>> with coaster. The swift
>>>> I am running is at
>>>> [zzhang at login2 final]$ which swift
>>>> /home/wilde/bigdata/swift/bin/swift
>>>> I am confused about the configuration settings in the sites.xml
>>>> file. Could anybody point the
>>>> error in the settings? thanks.
>>>> Best
>>>> zhao
>>>> PS: I am pasting my pbs.xml and stdout from swift here.
>>>> <config>
>>>>  <pool handle="pbs">
>>>>    <profile namespace="globus" key="coastersPerNode">8</profile>
>>>>    <profile namespace="karajan" key="initialScore">10000</profile>
>>>>  </pool>
>>>> [zzhang at login2 final]$ time swift -tc.file ./tc sites.file ./pbs.xml
>>>> movie.swift
>>>> Swift svn swift-r3255 (swift modified locally) cog-r2723
>>>> RunID: 20100228-0003-xeza2uh4
>>>> Progress:
>>>> Progress:Progress:  uninitialized:3  uninitialized:3
>>>> Progress:  Selecting site:936  Stage in:54  Submitting:1  Submitted:9
>>>> Progress:  Selecting site:936  Stage in:21  Submitted:43
>>>> Worker task failed: Error submitting block task
>>>> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
>>>> Cannot submit job: Could not submit job (qsub reported an exit code
>>>> of 188).
>>>> qsub: Job exceeds queue resource limits MSG=cannot locate feasible nodes
>>>>        at org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
>>>>        at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:46)
>>>>        at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:43)
>>>>        at org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.run(BlockTaskSubmitter.java:66)
>>>> Caused by:
>>>> org.globus.cog.abstraction.impl.scheduler.common.ProcessException:
>>>> Could not submit job (qsub reported an exit code of 188).
>>>>        at org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:100)
>>>>        at org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
>>>>        ... 3 more
>>>> Progress:  Selecting site:936  Submitted:63  Active:1
>>>> Failed to transfer wrapper log from
>>>> movie-20100228-0003-xeza2uh4/info/v on pbs
>>>> Execution failed:
>>>>        Exception in transform:
>>>> Arguments: [training_set_1000/mv_0001283.txt]
>>>> Host: pbs
>>>> Directory: movie-20100228-0003-xeza2uh4/jobs/v/transform-vt0goeoj
>>>> stderr.txt:
>>>> stdout.txt:
>>>> Caused by:
>>>>        Task failed: Error submitting block task
>>>> of 188).
>>>> Caused by:
>>>>        ... 3 more
>>>> Cleaning up...
>>>> Shutting down service at https://192.5.86.6:50002
>>>> Got channel MetaChannel: 2090567670 -> null
>>>> +Canceling job 5536.svc.pads.ci.uchicago.edu
>>>> Canceling job 5537.svc.pads.ci.uchicago.edu
>>>> Canceling job 5538.svc.pads.ci.uchicago.edu
>>>> Failed to shut down block
>>>> Can only cancel an active task
>>>>        at org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.cancel(AbstractExecutor.java:177)
>>>>        at org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.cancel(AbstractJobSubmissionTaskHandler.java:85)
>>>>        at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.cancel(AbstractTaskHandler.java:70)
>>>>        at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.cancel(ExecutionTaskHandler.java:96)
>>>>        at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.cancel(ExecutionTaskHandler.java:85)
>>>>        at org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.cancel(BlockTaskSubmitter.java:44)
>>>>        at org.globus.cog.abstraction.coaster.service.job.manager.Block.forceShutdown(Block.java:271)
>>>>        at org.globus.cog.abstraction.coaster.service.job.manager.Block.shutdown(Block.java:252)
>>>>        at org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdownBlocks(BlockQueueProcessor.java:487)
>>>>        at org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdown(BlockQueueProcessor.java:477)
>>>>        at org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.shutdown(JobQueue.java:70)
>>>>        at org.globus.cog.abstraction.coaster.service.CoasterService.shutdown(CoasterService.java:211)
>>>>        at org.globus.cog.abstraction.coaster.service.ServiceShutdownHandler.requestComplete(ServiceShutdownHandler.java:28)
>>>>        at org.globus.cog.karajan.workflow.service.handlers.RequestHandler.receiveCompleted(RequestHandler.java:84)
>>>>        at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleRequest(AbstractKarajanChannel.java:348)
>>>>        at org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.sendTaggedData(AbstractPipedChannel.java:58)
>>>>        at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.sendTaggedData(AbstractKarajanChannel.java:126)
>>>>        at org.globus.cog.karajan.workflow.service.commands.Command.send(Command.java:121)
>>>>        at org.globus.cog.karajan.workflow.service.commands.Command.send(Command.java:171)
>>>>        at org.globus.cog.karajan.workflow.service.commands.Command.executeAsync(Command.java:162)
>>>>        at org.globus.cog.abstraction.impl.execution.coaster.ServiceManager$ServiceReaper.run(ServiceManager.java:425)
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
