[Swift-user] passing a file as an argument
J A jamalphd at gmail.com
Mon Feb 1 20:14:36 CST 2010
Hi:
I tried that but got an error ...
*the command is:*
$ swift  CreateFiles.swift  -fname=list.txt
*My code looks like this:*
type file{};
type messagefile {};
//file list<"list.txt">;     // if I uncomment this line and comment the
next line, my code will work fine but I want the file name
                                 // to be dynamic
file list<@arg("fname")>;
*The error I got was:*
Could not compile SwiftScript source: line 7:11: unexpected token: @
Thanks for your help.
Jamal
On 1/31/10, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Jamal, for this, you pass the file name on the command line as a script
> argument after all the swift command arguments, and pick it up inside your
> swift script with the @arg() function, which is like argv in C (except
> indexed by name rather than position). Its described in the User Guide.
> - Mike
> ----- "J A" <jamalphd at gmail.com> wrote:
> > Hi:
> > how can I pass a file when executing swift, so i want to do something
> > like this:
> > $ swift file.txt
> > how do I catch the file inside the code?
> > Thanks,
> > Jamal
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100201/1ac65385/attachment.html>
More information about the Swift-user mailing list
