[Swift-user] reducing SetFieldValue logging levels
Allan Espinosa aespinosa at cs.uchicago.edu
Wed Dec 1 14:17:22 CST 2010
I set the logging level of SetFieldValue to NONE but still receive its
log entries:
$ grep SetFieldValue postproc-20101201-1412-58dz3i1h.log | head -n 10
2010-12-01 14:12:26,567-0600 DEBUG SetFieldValue Setting
org.griphyn.vdl.mapping.RootDataNode identifier
dataset:20101201-1412-y0ba3ap8:720000000048 type int with no value at
dataset=num_time_steps (not closed) to 3000
dataset:20101201-1412-y0ba3ap8:720000000049 type string with no value
at dataset=spectra_period1 (not closed) to all
dataset:20101201-1412-y0ba3ap8:720000000050 type float with no value
at dataset=filter_highhz (not closed) to 5.0
dataset:20101201-1412-y0ba3ap8:720000000053 type string with no value
at dataset=datadir (not closed) to
gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/Results
dataset:20101201-1412-y0ba3ap8:720000000051 type float with no value
at dataset=simulation_timeskip (not closed) to 0.1
2010-12-01 14:12:26,568-0600 DEBUG SetFieldValue Setting
dataset:20101201-1412-y0ba3ap8:720000000052 type int with no value at
dataset=run_id (not closed) to 664
dataset:20101201-1412-y0ba3ap8:720000000057 type string with no value
at dataset=swift#mapper#17045 (not closed) to
gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/SgtFiles
2010-12-01 14:12:26,570-0600 DEBUG SetFieldValue Setting
dataset:20101201-1412-y0ba3ap8:720000000056 type string with no value
at dataset=swift#mapper#17044 (not closed) to
org.griphyn.vdl.mapping.DataNode identifier
dataset:20101201-1412-y0ba3ap8:720000000062 type string with no value
at dataset=site path=.name (not closed)
Do i have some conflicting logging config here?  my log4j.properties:
log4j.rootCategory=INFO, CONSOLE, FILE
log4j.appender.CONSOLE=org.apache.log4j.ConsoleAppender
log4j.appender.CONSOLE.layout=org.apache.log4j.PatternLayout
log4j.appender.CONSOLE.Threshold=INFO
log4j.appender.CONSOLE.layout.ConversionPattern=%m%n
log4j.appender.FILE=org.apache.log4j.RollingFileAppender
log4j.appender.FILE.MaxFileSize=1GB
log4j.appender.FILE.File=swift.log
log4j.appender.FILE.layout=org.apache.log4j.PatternLayout
log4j.appender.FILE.layout.ConversionPattern=%d{yyyy-MM-dd
HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n
log4j.logger.swift=INFO
log4j.logger.org.apache.axis.utils=ERROR
log4j.logger.org.globus.swift.trace=INFO
log4j.logger.org.griphyn.vdl.karajan.Loader=DEBUG
log4j.logger.org.globus.cog.karajan.workflow.events.WorkerSweeper=WARN
log4j.logger.org.globus.cog.karajan.workflow.nodes.FlowNode=WARN
log4j.logger.org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler=DEBUG
log4j.logger.org.griphyn.vdl.toolkit.VDLt2VDLx=DEBUG
log4j.logger.org.griphyn.vdl.karajan.VDL2ExecutionContext=DEBUG
log4j.logger.org.globus.cog.abstraction.impl.common.task.TaskImpl=INFO
#log4j.logger.org.griphyn.vdl.karajan.lib.GetFieldValue=DEBUG
log4j.logger.org.griphyn.vdl.engine.Karajan=INFO
log4j.logger.org.globus.cog.abstraction.coaster.rlog=DEBUG
# log4j.logger.org.globus.swift.data.Director=DEBUG
#log4j.logger.swift=DEBUG
log4j.logger.org.griphyn.vdl.karajan.lib=NONE
log4j.logger.org.griphyn.vdl.karajan.lib.SetFieldValue=NONE
log4j.logger.org.griphyn.vdl.mapping.AbstractDataNode=NONE
Allan M. Espinosa <http://amespinosa.wordpress.com>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
More information about the Swift-user mailing list
