[Swift-user] Coaster error
Mihael Hategan hategan at mcs.anl.gov
Thu Aug 5 15:34:58 CDT 2010
Ignore the message I just sent.
On Thu, 2010-08-05 at 15:33 -0500, Mihael Hategan wrote:
> It means that qstat failed for some reason.
> Can you reproduce it?
> On Thu, 2010-08-05 at 14:11 -0500, Jonathan Monette wrote:
> > Hello again,
> >      Also has anyone seen this error and know what it means?
> > Worker task failed:
> > org.globus.cog.abstraction.impl.common.execution.JobException: Job
> > failed with an exit code of 29
> >      at
> > org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.processCompleted(AbstractJobSubmissionTaskHandler.java:95)
> >      at
> > org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.processCompleted(AbstractExecutor.java:240)
> >      at
> > org.globus.cog.abstraction.impl.scheduler.common.Job.processExitCode(Job.java:104)
> >      at
> > org.globus.cog.abstraction.impl.scheduler.common.Job.close(Job.java:81)
> >      at
> > org.globus.cog.abstraction.impl.scheduler.common.Job.setState(Job.java:177)
> >      at
> > org.globus.cog.abstraction.impl.scheduler.pbs.QueuePoller.processStdout(QueuePoller.java:126)
> >      at
> > org.globus.cog.abstraction.impl.scheduler.common.AbstractQueuePoller.pollQueue(AbstractQueuePoller.java:169)
> >      at
> > org.globus.cog.abstraction.impl.scheduler.common.AbstractQueuePoller.run(AbstractQueuePoller.java:82)
> >      at java.lang.Thread.run(Thread.java:619)
More information about the Swift-user mailing list
