[Swift-user] Can`t run the first.swift
Mihael Hategan
hategan at mcs.anl.gov
Fri Apr 2 15:01:16 CDT 2010
On Fri, 2010-04-02 at 23:49 +0530, Amila Madusanka wrote:
> I set the "path" environment variable.
> And go to example dir and use command "swift first.swift" (As in
> Swift Quickstart Guide)
1. You should keep the mailing list CC-ed.
2. We don't support windows much. It's more like we try to make it run
there, but there are no guarantees. So you have two choices:
a) Try to troubleshoot and fix the problems on windows, which would
become part of your GSOC contributions to the project.
b) Install cygwin or use linux
3. I don't think Swift 0.8 works with Windows. I would recommend trying
the SVN version, either the stable branch or trunk. If you are going to
be a GSOC student for Swift, that is the code you will work with.
4. Read
http://www.ci.uchicago.edu/swift/guides/userguide.php#tips.windows
Mihael
More information about the Swift-user
