[Swift-user] Chesnoknov workflow
Wei Tan
wtan at mcs.anl.gov
Tue Oct 27 11:49:54 CDT 2009
I got this result when running swift-plot-log
Log file path is /tmp/wtan/workingdir/ecg3-20091026-1332-fkizh09c.log
Log is in directory /tmp/wtan/workingdir
Log basename is ecg3-20091026-1332-fkizh09c
Now in directory /tmp/swift-plot-log-btGjiRNxbiel5334
make: ../swift-0.9/bin/../libexec/log-processing//makefile: No such file
or directory
make: *** No rule to make target
`../swift-0.9/bin/../libexec/log-processing//makefile'. Stop.
From the webpage, it seems that I need to install gnuplot 4.0, gnu m4,
gnu textutils, perl first?
I am working on it and will post the result here.
Wei
Michael Wilde wrote:
> More documentation on the log processing tools is at:
> http://www.ci.uchicago.edu/swift/guides/log-processing.php
> - Mike
> On 10/26/09 5:28 PM, Michael Wilde wrote:
>> Wei, its the swift-plot-log command, in the Swift user guide at:
>> http://www.ci.uchicago.edu/swift/guides/userguide.php#id2711073
>> - Mike
>> On 10/26/09 5:24 PM, Ian Foster wrote:
>>> Hi Wei:
>>> I can't recall the details, but there are nice tools for generating
>>> a Web page with plots.
>>> Ian/
>>> On Oct 26, 2009, at 5:18 PM, Wei Tan wrote:
>>>> Hi Ian,
>>>> I am not sure which log plots you are talking about. But my
>>>> working directory is
>>>> crush.mcs.anl.gov/tmp/wtan, I guess you can find all the logs you
>>>> want to see there?
>>>> To be more specific:
>>>> /workingdir: the directory from which I issue the command line
>>>> swift ...:there are some error logs since there are 23/1141
>>>> failure jobs.
>>>> /ecg3... directory generated when running swift workflow
>>>> /swift-workflows the directory containing the workflow
>>>> /app: the directory containing the executable and the input files
>>>> /swift-0.9 the swift installation directory
>>>> Best regards,
>>>> Wei
>>>> Ian Foster wrote:
>>>>> that's great. Do you have the Swift log plots?
>>>>> On Oct 26, 2009, at 4:56 PM, Wei Tan wrote:
>>>>>> Hi Mike and others,
>>>>>> A recapture of the story:
>>>>>> We have a chesnokov workflow which contains a forEach and the
>>>>>> input file array has 1171 files.
>>>>>> Running it at a desktop and in a 32-core server have different
>>>>>> performance indexes, in terms of execution time
>>>>>> See
>>>>>> http://spreadsheets.google.com/ccc?key=0AriiWNEG__VUdEM0ampSaWRqcGROTW1TNE00X29GVHc&hl=en
>>>>>> --------------------the data Mike wants to
>>>>>> see---------------------------------------------
>>>>>> In the same 32-core machine (crush), using a local file system
>>>>>> instead of the share file system, will reduce the execution
>>>>>> time, from *2min20sec~2min50sec*, to *1min40sec~1min50sec*.
>>>>>> --------------------end of the the data Mike wants to
>>>>>> Best regards,
>>>>>> Wei
>>>>>> Wei Tan, Ph.D.
>>>>>> Computation Institute
>>>>>> the University of Chicago|Argonne National Laboratory
>>>>>> http://www.mcs.anl.gov/~wtan
>>>>>> _______________________________________________
>>>>>> Swift-user mailing list
>>>>>> Swift-user at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
>>>> Wei Tan, Ph.D.
Wei Tan, Ph.D.
More information about the Swift-user
