[Swift-user] Re: [Swift-devel] burnin' up ranger w/the latest coasters
skenny at uchicago.edu
Fri Oct 23 10:45:04 CDT 2009
however...when i use the configs here and i try to run a
workflow with 196,608 jobs it seems that coasters starts to
ramp up nicely, but maybe a little too well :) as it begins
requesting more cores than i'm allowed in the normal queue on
ranger. that is, the limit is 4096. i tried changing maxNodes
to 4096 which did not work. i'm wondering if workers per node
should actually be 16 instead (?) but i know you've gotten it
to work well with the setting at 32 so i'm not sure...
anyway, it ramped up nicely (and was only like 8 jobs away
from finishing the whole thing) i just need to know how to cap
it off so it won't ask for more than 4096 cores.
thanks
~sk
---- Original message ----
>Date: Wed, 14 Oct 2009 15:39:15 -0500 (CDT)
>From: <skenny at uchicago.edu>
>Subject: Re: [Swift-devel] burnin' up ranger w/the latest
coasters
>To: swift-user at ci.uchicago.edu, swift-devel at ci.uchicago.edu
>for those interested, here are the config files used for this
run:
>swift.properties:
>sites.file=config/coaster_ranger.xml
>tc.file=/ci/projects/cnari/config/tc.data
>lazy.errors=false
>caching.algorithm=LRU
>pgraph=false
>pgraph.graph.options=splines="compound", rankdir="TB"
>pgraph.node.options=color="seagreen", style="filled"
>clustering.enabled=false
>clustering.queue.delay=4
>clustering.min.time=60
>kickstart.enabled=maybe
>kickstart.always.transfer=false
>wrapperlog.always.transfer=false
>throttle.submit=3
>throttle.host.submit=8
>throttle.score.job.factor=64
>throttle.transfers=16
>throttle.file.operations=16
>sitedir.keep=false
>execution.retries=3
>replication.enabled=false
>replication.min.queue.time=60
>replication.limit=3
>foreach.max.threads=16384
>coaster_ranger.xml:
><config>
> <import file="sys.xml"/>
><import file="vdl-lib.xml"/>
><set name="username">
> <arg><vdl:new type="string" value="user"/></arg>
></set>
><pool handle="RANGER">
> <profile namespace="karajan"
>key="jobThrottle">1000.0</profile>
> <filesystem provider="coaster"
>url="gt2://gatekeeper.ranger.tacc.teragrid.org"/>
> <profile namespace="globus" key="queue">normal</profile>
> <profile namespace="globus" key="workersPerNode">32</profile>
> <profile namespace="globus" key="nodeGranularity">1</profile>
> <profile namespace="globus" key="slots">16</profile>
> <profile namespace="globus" key="maxNodes">8192</profile>
> <profile namespace="globus" key="maxTime">72000</profile>
>key="project">TG-DBS080004N</profile>
> <execution provider="coaster"
>url="gatekeeper.ranger.tacc.teragrid.org"
>jobManager="gt2:gt2:SGE"/>
>workdirectory>/work/00043/tg457040/sidgrid_out/{username}</workdirectory
><workdirectory>/work/00926/tg459516/sidgrid_out/{username}</workdirectory>
> </pool>
></config>
>>Date: Tue, 13 Oct 2009 11:14:17 -0500 (CDT)
>>Subject: [Swift-devel] burnin' up ranger w/the latest coasters
>>To: swift-devel at ci.uchicago.edu
>>Final status: Finished successfully:131072
>>re-running some of the workflows from our recent SEM
>>paper with the latest swift...sadly, queue time on ranger has
>>only gone up since those initial runs...but luckily coasters
>>has speeded things up, so it ends up evening out for time to
>>solution :)
>>not sure i fully understand the plot:
>>http://www.ci.uchicago.edu/~skenny/workflows/sem_131k/
>>log is here:
>>/ci/projects/cnari/logs/skenny/4reg_2cond-20091012-1607-ugidm2s2.log
>>_______________________________________________
>>Swift-devel mailing list
>>Swift-devel at ci.uchicago.edu
>>http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
More information about the Swift-user
