[Swift-user] using swift on a cluster
Michael Wilde wilde at mcs.anl.gov
Wed Oct 21 12:36:43 CDT 2009
Erin,
The first line of your sites.xml file seems to be left there in error:
  > [hodgess at grid bin]$ cat sites.xml
  > <execution provider="condor" url="none" />
Can you remove that and try again? Im not sure how that got parsed.
- Mike
On 10/21/09 12:10 PM, Hodgess, Erin wrote:
> Hi again!
> Here are the sites.xml and tc.data files.
> Thanks,
> Erin
> <config>
>    <pool handle="localhost">
>      <gridftp url="local://localhost" />
>      <execution provider="local" url="none" />
>      <workdirectory>/home/hodgess/swiftwork</workdirectory>
>      <profile namespace="karajan" key="jobThrottle">.03</profile>
>      <profile namespace="karajan" key="initialScore">10000</profile>
>    </pool>
>    <pool handle="condor">
>      <execution provider="condor" url="none"/>
>      <gridftp url="local://localhost"/>
>      <profile namespace="karajan" key="jobThrottle">.19</profile>
>    </pool>
> </config>
> [hodgess at grid bin]$ cat tc.data
> localhost       convert /usr/bin/convert        INSTALLED
> INTEL32::LINUX null
> localhost       RInvoke /home/hodgess/R-2.9.2/bin/RInvoke.sh
> INSTALLED      INTEL32::LINUX   null
> condor  RInvoke /home/hodgess/R-2.9.2/bin/RInvoke.sh    INSTALLED
> INTEL32::LINUX  null
> [hodgess at grid bin]$ cat firstR.R
> cat: firstR.R: No such file or directory
> [hodgess at grid bin]$ cat firstR.swift
> type file{}
> app (file output) firstone (file scriptFile) {
>     RInvoke  @filename(scriptFile) @filename(output);
>         file scriptFile <"a1.in" >;
>         file output <"a1.out" >;
>             output=firstone(scriptFile);
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> -----Original Message-----
> From: Michael Wilde [mailto:wilde at mcs.anl.gov]
> Sent: Wed 10/21/2009 9:22 AM
> To: Hodgess, Erin
> Cc: swift-user at ci.uchicago.edu
> Subject: Re: [Swift-user] using swift on a cluster
> Erin, we need to look into this further.
> Please make sure that you are running either Swift 0.9 or the latest
> source from svn. And tell us what revision you are running.
> Also please post your tc.data and sites.xml (and log file is its small
> enought); see if there are any messages in the .log file that would
> clarify the error.
> Make sure that your app is cataloged in tc.data as being on pool
> "condor". But I think if it were not, you'd see a different error.
> It almost looks to me like Swift is looking for the GRAM service contact
> string, as if it thinks you are asking for Condor-G instead of local
> Condor, eg:
>   <profile namespace="globus" key="jobType">grid</profile>
>    key="gridResource">gt2 belhaven-1.renci.org/jobmanager-fork</profile>
> Just as a test, try changing provider="condor" to "pbs" in sites.xml. If
> the error changes to something like "PBS not installed" or "qsub not
> found" then I would suspect this is the case.
> Its possible you can add just the jobType element with the value set to
> vanilla instead of grid, but I am purely *guessing*; we'll look deeper
> as soon as you send the info above and we have time.
> - Mike
> On 10/21/09 9:03 AM, Hodgess, Erin wrote:
>  > Here is the output:
>  > [hodgess at grid bin]$ swift -tc.file tc.data -sites.file sites.xml
>  > firstR.swift
>  > Swift 0.9 swift-r2860 cog-r2388
>  > RunID: 20091021-0901-aku7y862
>  > Progress:
>  > Execution failed:
>  >         No service contacts available
>  > Associate Professor
>  > Sent: Wed 10/21/2009 7:02 AM
>  > To: Hodgess, Erin
>  > For running Swift locally on a Condor cluster, use a sites.xml based on
>  > this example:
>  > <config>
>  >      <workdirectory>/home/erin/swiftwork</workdirectory>
>  >    </pool>
>  >    </pool>
>  > </config>
>  > The jobThrottle values above will enable Swift to run up to 4 jobs at a
>  > time on localhost and 20 jobs at a time on the Condor cluster.
>  > Use tc.data to catalog applications on pool or the other.
>  > Set jobThrottle as desired to control execution parallelism.
>  > #jobs run in parallel is (jobThrottle * 100)+1
>  > initialScore=10000 overrides Swift's "start slow" approach to sensing
>  > the site's responsiveness.
>  > - Mike
>  > On 10/21/09 3:17 AM, Hodgess, Erin wrote:
>  >  > Aha!
>  >  > I needed the universe=vanilla line.
>  >  > Associate Professor
>  >  > From: swift-user-bounces at ci.uchicago.edu on behalf of Hodgess, Erin
>  >  > Sent: Wed 10/21/2009 3:07 AM
>  >  > To: Michael Wilde
>  >  > Subject: RE: [Swift-user] using swift on a cluster
>  >  > Hello!
>  >  > We are indeed using condor.
>  >  > I wanted to try a small test run, but am running into trouble:
>  >  > [hodgess at grid bin]$ cat myjob.submit
>  >  > executable=/usr/bin/id
>  >  > output=results.output
>  >  > error=results.error
>  >  > log=results.log
>  >  > queue
>  >  > [hodgess at grid bin]$ condor_submit myjob.submit
>  >  > Submitting job(s).
>  >  > Logging submit event(s).
>  >  > 1 job(s) submitted to cluster 15.
>  >  > [hodgess at grid bin]$ ls results*
>  >  > results.error  results.log  results.output
>  >  > You have new mail in /var/spool/mail/hodgess
>  >  > [hodgess at grid bin]$ cat results.log
>  >  > 000 (015.000.000) 10/21 03:06:03 Job submitted from host:
>  >  > <192.168.1.11:46274>
>  >  > 001 (015.000.000) 10/21 03:06:05 Job executing on host:
>  > <10.1.255.244:44508>
>  >  > 002 (015.000.000) 10/21 03:06:05 (1) Job not properly linked for
> Condor.
>  >  > 009 (015.000.000) 10/21 03:06:05 Job was aborted by the user.
>  >  > I'm not sure why the job is not linked.
>  >  > Any suggestions would be much appreciated.
>  >  > Thanks,
>  >  > Erin
>  >  > Associate Professor
>  >  > Sent: Tue 10/20/2009 10:49 PM
>  >  > To: Hodgess, Erin
>  >  > Hi Erin,
>  >  > I'm assuming you meant "use Swift to run jobs on the compute nodes of
>  >  > the cluster"?
>  >  > If so, you first need to find out what scheduler (also called "batch
>  >  > system" or "local resource manager") the cluster is running.
>  >  > Thats typical one of these: PBS, Condor, or SGE.
>  >  > Either ask your system administrator, or see if the "man" command or
>  >  > similar probes give you a clue:
>  >  > Condor: condor_q -version
>  >  > condor_q -version
>  >  > $CondorVersion: 7.2.4 Jun 16 2009 BuildID: 159529 $
>  >  > $CondorPlatform: I386-LINUX_RHEL5 $
>  >  > PBS: man qstat:
>  >  >    qstat(1B)  PBS
>  >  > SGE: man qstat:
>  >  >    QSTAT(1)   Sun Grid Engine User Commands
>  >  > If its PBS or Condor, then the Swift user guide gives the sites.xml
>  >  > entries to use.
>  >  > Tell us what you find, then try following the instructions in the user
>  >  > guide, and follow up with questions as needed.
>  >  > - Mike
>  >  > On 10/20/09 9:41 PM, Hodgess, Erin wrote:
>  >  >  > Hi Swift Users:
>  >  >  > I'm on a cluster and would like to use swift on the different
> sites on
>  >  >  > the cluster.
>  >  >  > How would I do that, please?
>  >  >  > Thanks,
>  >  >  > Erin
>  >  >  > Associate Professor
>  >  >  > _______________________________________________
>  >  >  > Swift-user mailing list
>  >  >  > Swift-user at ci.uchicago.edu
>  >  >  > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
