[Swift-user] using swift on a cluster
Michael Wilde
wilde at mcs.anl.gov
Wed Oct 21 09:22:35 CDT 2009
Erin, we need to look into this further.
Please make sure that you are running either Swift 0.9 or the latest
source from svn. And tell us what revision you are running.
Also please post your tc.data and sites.xml (and log file is its small
enought); see if there are any messages in the .log file that would
clarify the error.
Make sure that your app is cataloged in tc.data as being on pool
"condor". But I think if it were not, you'd see a different error.
It almost looks to me like Swift is looking for the GRAM service contact
string, as if it thinks you are asking for Condor-G instead of local
Condor, eg:
<profile namespace="globus" key="jobType">grid</profile>
key="gridResource">gt2 belhaven-1.renci.org/jobmanager-fork</profile>
Just as a test, try changing provider="condor" to "pbs" in sites.xml. If
the error changes to something like "PBS not installed" or "qsub not
found" then I would suspect this is the case.
Its possible you can add just the jobType element with the value set to
vanilla instead of grid, but I am purely *guessing*; we'll look deeper
as soon as you send the info above and we have time.
- Mike
On 10/21/09 9:03 AM, Hodgess, Erin wrote:
> Here is the output:
> [hodgess at grid bin]$ swift -tc.file tc.data -sites.file sites.xml
> firstR.swift
> Swift 0.9 swift-r2860 cog-r2388
> RunID: 20091021-0901-aku7y862
> Progress:
> Execution failed:
> No service contacts available
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> -----Original Message-----
> From: Michael Wilde [mailto:wilde at mcs.anl.gov]
> Sent: Wed 10/21/2009 7:02 AM
> To: Hodgess, Erin
> Cc: swift-user at ci.uchicago.edu
> Subject: Re: [Swift-user] using swift on a cluster
> For running Swift locally on a Condor cluster, use a sites.xml based on
> this example:
> <execution provider="condor" url="none" />
> <config>
> <pool handle="localhost">
> <gridftp url="local://localhost" />
> <execution provider="local" url="none" />
> <workdirectory>/home/erin/swiftwork</workdirectory>
> <profile namespace="karajan" key="jobThrottle">.03</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> </pool>
> <pool handle="condor">
> <execution provider="condor" url="none"/>
> <gridftp url="local://localhost"/>
> <profile namespace="karajan" key="jobThrottle">.19</profile>
> </pool>
> </config>
> The jobThrottle values above will enable Swift to run up to 4 jobs at a
> time on localhost and 20 jobs at a time on the Condor cluster.
> Use tc.data to catalog applications on pool or the other.
> Set jobThrottle as desired to control execution parallelism.
> #jobs run in parallel is (jobThrottle * 100)+1
> initialScore=10000 overrides Swift's "start slow" approach to sensing
> the site's responsiveness.
> - Mike
> On 10/21/09 3:17 AM, Hodgess, Erin wrote:
> > Aha!
> > I needed the universe=vanilla line.
> > Associate Professor
> > From: swift-user-bounces at ci.uchicago.edu on behalf of Hodgess, Erin
> > Sent: Wed 10/21/2009 3:07 AM
> > To: Michael Wilde
> > Subject: RE: [Swift-user] using swift on a cluster
> > Hello!
> > We are indeed using condor.
> > I wanted to try a small test run, but am running into trouble:
> > [hodgess at grid bin]$ cat myjob.submit
> > executable=/usr/bin/id
> > output=results.output
> > error=results.error
> > log=results.log
> > queue
> > [hodgess at grid bin]$ condor_submit myjob.submit
> > Submitting job(s).
> > Logging submit event(s).
> > 1 job(s) submitted to cluster 15.
> > [hodgess at grid bin]$ ls results*
> > results.error results.log results.output
> > You have new mail in /var/spool/mail/hodgess
> > [hodgess at grid bin]$ cat results.log
> > 000 (015.000.000) 10/21 03:06:03 Job submitted from host:
> > <192.168.1.11:46274>
> > 001 (015.000.000) 10/21 03:06:05 Job executing on host:
> <10.1.255.244:44508>
> > 002 (015.000.000) 10/21 03:06:05 (1) Job not properly linked for Condor.
> > 009 (015.000.000) 10/21 03:06:05 Job was aborted by the user.
> > I'm not sure why the job is not linked.
> > Any suggestions would be much appreciated.
> > Thanks,
> > Erin
> > Associate Professor
> > Sent: Tue 10/20/2009 10:49 PM
> > To: Hodgess, Erin
> > Hi Erin,
> > I'm assuming you meant "use Swift to run jobs on the compute nodes of
> > the cluster"?
> > If so, you first need to find out what scheduler (also called "batch
> > system" or "local resource manager") the cluster is running.
> > Thats typical one of these: PBS, Condor, or SGE.
> > Either ask your system administrator, or see if the "man" command or
> > similar probes give you a clue:
> > Condor: condor_q -version
> > condor_q -version
> > $CondorVersion: 7.2.4 Jun 16 2009 BuildID: 159529 $
> > $CondorPlatform: I386-LINUX_RHEL5 $
> > PBS: man qstat:
> > qstat(1B) PBS
> > SGE: man qstat:
> > QSTAT(1) Sun Grid Engine User Commands
> > If its PBS or Condor, then the Swift user guide gives the sites.xml
> > entries to use.
> > Tell us what you find, then try following the instructions in the user
> > guide, and follow up with questions as needed.
> > - Mike
> > On 10/20/09 9:41 PM, Hodgess, Erin wrote:
> > > Hi Swift Users:
> > > I'm on a cluster and would like to use swift on the different sites on
> > > the cluster.
> > > How would I do that, please?
> > > Thanks,
> > > Erin
> > > Associate Professor
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
