[Swift-user] Using swift for PCs
Michael Wilde
wilde at mcs.anl.gov
Thu Oct 1 13:29:54 CDT 2009
Mark, the swift command should set $SWIFT_HOME by finding where it was
executed from. That logic seems not to be working under cygwin, likely
due to some shell or command differences. We'll need to investigate, but
perhaps this gives you a clue to help you to down the problem.
- Mike
On 10/1/09 12:19 PM, Altaweel, Mark R. wrote:
> Hi,
> I just started trying to use swift, and we are investigating to see if
> swift can be useful for our applications. Our users apply windows, mac,
> and linux/unix environments for their work, so we need to have swift
> work on all three platforms. I got it to run on the mac and linux side
> of things, but I am having a little trouble running it on windows.
> First, I am trying to run swift-0.9 through cygwin. I followed the
> install instructions for swift and when I tried to run any of the demos
> (e.g., first.swift) I get this error:
> SWIFT_HOME is not set, and all attempts at guessing it failed.
> However, I did set SWIFT_HOME in the System. I am not sure what the
> problem is. Any hints would be appreciated.
> Thanks.
> Mark
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
