[Swift-user] How to set GLOBUS_HOSTNAME for ALCF Viz systems?
Michael Wilde
wilde at mcs.anl.gov
Tue Nov 17 10:56:37 CST 2009
Im unsure - it has the same IP net address as the suggested setting for
GLOBUS_HOSTNAME that Mihael gave for Surveyor.
On 11/17/09 8:40 AM, Allan Espinosa wrote:
> I thought myri0 was the interface that connects to the DDN.
> 2009/11/17 Michael Wilde <wilde at mcs.anl.gov>:
>> What interface should GLOBUS_HOSTNAME be set to, eg on Eureka?
>> eth4 10. net
>> eth5 140. net
>> myri0 172. net
>> Im guessing myri0 here, for the compute node to reach the login node???
>> - Mike
>> eth4 Link encap:Ethernet HWaddr 00:30:48:D1:0B:A2
>> inet addr:10.40.9.151 Bcast:10.40.255.255 Mask:255.255.0.0
>> inet6 addr: fe80::230:48ff:fed1:ba2/64 Scope:Link
>> UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
>> RX packets:430006791 errors:0 dropped:105781973 overruns:0 frame:0
>> TX packets:1487287 errors:0 dropped:0 overruns:0 carrier:0
>> collisions:0 txqueuelen:1000
>> RX bytes:28555408302 (27232.5 Mb) TX bytes:701260634 (668.7 Mb)
>> Memory:d9540000-d9560000
>> eth5 Link encap:Ethernet HWaddr 00:30:48:D1:0B:A3
>> inet addr:140.221.82.124 Bcast:140.221.82.255 Mask:255.255.255.0
>> inet6 addr: fe80::230:48ff:fed1:ba3/64 Scope:Link
>> RX packets:81373909 errors:0 dropped:0 overruns:0 frame:0
>> TX packets:166797316 errors:0 dropped:0 overruns:0 carrier:0
>> RX bytes:6260202432 (5970.1 Mb) TX bytes:235189046440 (224293.7
>> Mb)
>> Memory:d9580000-d95a0000
>> lo Link encap:Local Loopback
>> inet addr:127.0.0.1 Mask:255.0.0.0
>> inet6 addr: ::1/128 Scope:Host
>> UP LOOPBACK RUNNING MTU:16436 Metric:1
>> RX packets:9421943 errors:0 dropped:0 overruns:0 frame:0
>> TX packets:9421943 errors:0 dropped:0 overruns:0 carrier:0
>> collisions:0 txqueuelen:0
>> RX bytes:3160789166 (3014.3 Mb) TX bytes:3160789166 (3014.3 Mb)
>> myri0 Link encap:Ethernet HWaddr 00:60:DD:46:F9:02
>> inet addr:172.17.9.151 Bcast:172.31.255.255 Mask:255.240.0.0
>> inet6 addr: fe80::260:ddff:fe46:f902/64 Scope:Link
>> UP BROADCAST RUNNING MULTICAST MTU:9000 Metric:1
>> RX packets:252551665 errors:0 dropped:0 overruns:0 frame:0
>> TX packets:141201312 errors:0 dropped:0 overruns:0 carrier:0
>> RX bytes:809041321883 (771561.9 Mb) TX bytes:556774673980
>> (530981.7 Mb)
>> Interrupt:210
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
