[Swift-user] cobalt can't find wrapperlogs
Mihael Hategan
hategan at mcs.anl.gov
Tue Nov 3 17:41:49 CST 2009
On Tue, 2009-11-03 at 17:34 -0600, Allan Espinosa wrote:
> ahh right.
> the way of running mpi jobs on Intrepid is different from what's the
> recommended procedure in the swift webpage. on the bluegene the
> actual "mpirun ./a.out" is equivalent to "cqsub ./a.out" itself.
I know.
But you can run cnk executables on zeptoos.
And I assume that since the swift wrapper is started by mpirun, the mpi
environment will be set-up, so it should apply ok to the executable that
the wrapper forks.
So I'd say just change to zeptoos and try again. I suspect it might
work.
> 2009/11/3 Mihael Hategan <hategan at mcs.anl.gov>:
> > Oh, no coasters. I see.
> > I don't think the swift wrapper will work on CNK.
More information about the Swift-user
