[Swift-user] Re: [Swift-devel] Issues when running swift on fuse
Mihael Hategan hategan at mcs.anl.gov
Fri May 29 04:02:54 CDT 2009
That's strange. You are getting multiple errors, both for the log file
and the restart log. But the restart log should be small (and for
first.swift, so should be the execution log). So I suspect the error
message is misleading.
Can you provide more details? Such as:
- the actual size of the files in question at the time the error(s)
occurred
- the motivation behind having the swift working directory (as opposed
to just the data) on S3
- any relevant quotas or limitations of the S3 fs (output of 'quota' if
applicable and 'df').
On Fri, 2009-05-29 at 02:13 -0500, yizhu wrote:
> Hi,
> I tried to run a swift on a directory mounted by fuse (s3fs), but got
> the following error:
> (-debug output attached)
> since I execute swift on /mnt/s3, the output file should be write
> there,i had rw permission on /mnt/s3, the job seems run correctly (the
> output file: Hello.txt is there), just a issue with log file.
> Is there a way to turn off the logging or any ideas to solve this problem?
> Thank you very much!
> -From
> Yi Zhu
> [torqueuser at ip-10-251-89-208 ~]$ cd /mnt/s3
> [torqueuser at ip-10-251-89-208 s3]$ swift
> /home/torqueuser/swift-0.9/examples/swift/first.swift
> log4j:ERROR Failed to flush writer,
> java.io.IOException: File too large
> 	at java.io.FileOutputStream.writeBytes(Native Method)
> 	at java.io.FileOutputStream.write(FileOutputStream.java:260)
> 	at sun.nio.cs.StreamEncoder$CharsetSE.writeBytes(StreamEncoder.java:336)
> 	at
> sun.nio.cs.StreamEncoder$CharsetSE.implFlushBuffer(StreamEncoder.java:404)
> 	at sun.nio.cs.StreamEncoder$CharsetSE.implFlush(StreamEncoder.java:408)
> 	at sun.nio.cs.StreamE.ncoder.flush(StreamEncoder.java:152)
> 	at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:213)
> 	at org.apache.log4j.helpers.QuietWriter.flush(QuietWriter.java:49)
> 	at org.apache.log4j.WriterAppender.subAppend(WriterAppender.java:306)
> 	at org.apache.log4j.WriterAppender.append(WriterAppender.java:150)
> 	at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:221)
> 	at
> org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders(AppenderAttachableImpl.java:57)
> 	at org.apache.log4j.Category.callAppenders(Category.java:187)
> 	at org.apache.log4j.Category.forcedLog(Category.java:372)
> 	at org.apache.log4j.Category.debug(Category.java:241)
> 	at org.griphyn.vdl.karajan.Loader.main(Loader.java:75)
> Swift 0.9 swift-r2860 cog-r2388
> RunID: 20090529-0204-55gjsnhc
> Progress:  uninitialized:1
> Progress:  Submitted:1
> Progress:  Active:1
> Ex098
> org.globus.cog.karajan.workflow.KarajanRuntimeException: Exception
> caught while writing to log file
> 	at
> org.globus.cog.karajan.workflow.nodes.restartLog.LogVargOperator.update(LogVargOperator.java:40)
> 	at
> org.globus.cog.karajan.workflow.nodes.functions.VariableArgumentsOperator.append(VariableArgumentsOperator.java:38)
> 	at
> org.globus.cog.karajan.workflow.nodes.functions.VariableArgumentsOperator.appendAll(VariableArgumentsOperator.java:44)
> 	at
> org.globus.cog.karajan.workflow.nodes.functions.VariableArgumentsOperator.merge(VariableArgumentsOperator.java:34)
> 	at
> org.globus.cog.karajan.workflow.nodes.SequentialChoice.commitBuffers(SequentialChoice.java:52)
> 	at
> org.globus.cog.karajan.workflow.nodes.SequentialChoice.childCompleted(SequentialChoice.java:41)
> 	at
> org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
> 	at
> org.globus.cog.karajan.workflow.nodes.SequentialChoice.notificationEvent(SequentialChoice.java:66)
> 	at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:332)
> 	at org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:125)
> 	at
> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
> 	at
> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:176)
> 	at
> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:296)
> 	at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
> 	at
> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
> 	at
> org.globus.cog.karajan.workflow.nodes.Sequential.childCompleted(Sequential.java:45)
> 	at
> 	at
> 	at
> 	at
> 	at
> 	at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
> 	at
> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
> 	at
> 	at
> 	at
> 	at
> 	at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:37)
> 	at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
> 	at
> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:233)
> 	at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:278)
> 	at
> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:391)
> 	at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:329)
> 	at
> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
> 	at
> 	at
> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
> Caused by: java.io.IOException: File too large
> 	at
> 	at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:152)
> 	at
> org.globus.cog.karajan.workflow.nodes.restartLog.FlushableLockedFileWriter.flush(FlushableLockedFileWriter.java:39)
> 	at
> org.globus.cog.karajan.workflow.nodes.restartLog.LogVargOperator.update(LogVargOperator.java:37)
> 	... 40 more
> Execution failed:
> 	Exception caught while writing to log file
> Caused by:
> 	File too large
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
More information about the Swift-user mailing list
