[Swift-user] Execution error
Ben Clifford
benc at hawaga.org.uk
Mon May 4 01:49:53 CDT 2009
One comment in general for debugging when you have some large application
workflow that appears to not run on a site, but runs on other sites, is to
try running examples/swift/first.swift from the Swift distribution using
the same sites file, and report whether that worked at the same time as
reporting your other problem.
If it fails, it is often easier to debug that for someone who does not
understand the specifics of your application.
More information about the Swift-user
