[Swift-user] Teragrid execution problem
Yue, Chen - BMD
yuechen at bsd.uchicago.edu
Fri Mar 20 14:53:59 CDT 2009
Hi Ben,
Thanks for answering my question. I tried the following command:
[yuechen at communicado PTMap]$ globus-url-copy file:///fasta334 gsiftp://gridftp-abe.ncsa.teragrid.org:2811/yuechen/tmp
GlobusUrlCopy error: UrlCopy transfer failed. [Caused by: Server refused performing the request. Custom message: Bad password. (error code 1) [Nested exception message: Custom message: Unexpected reply: 530-Login incorrect. : globus_gss_assist: Gridmap lookup failure: Could not map /DC=org/DC=doegrids/OU=People/CN=Yue Chen 509341
530-
530 End.]]
But I don't understand why it may fail, since I have performed grid-proxy-init and gx-request commands. Is it because the ftp server too busy?
I also tried SDSC clusters, but I got different error message. Is this also because of gsiftp issue?
sites.xml ---
<pool handle="SDSC_dtf_prews_pbs">
<gridftp url="gsiftp://tg-gridftp.sdsc.teragrid.org:2811/" />
<jobmanager universe="vanilla" url="tg-login1.sdsc.teragrid.org:2119/jobmanager-pbs" major="2" />
<workdirectory >/gpfs-wan/scratch/yuechen</workdirectory>
<profile namespace="globus" key="queue">fast</profile>
</pool>
tc.data ---
SDSC_dtf_prews_pbs PTMap /home/yuechen/PTMap/PTMap INSTALLED INTEL32::LINUX null
Error messages and globus-job-run test:
[yuechen at communicado PTMap]$ swift PTMap-unmod.swift -sites.file sites.xml -tc.file tc.data
Swift 0.8 swift-r2448 cog-r2261
RunID: 20090320-1433-oc8ufsv3
Progress:
Progress: Selecting site:9 Stage in:1 Initializing site shared directory:1
Progress: Selecting site:9 Stage in:2
Progress: Selecting site:9 Stage in:1 Submitting:1
Progress: Selecting site:9 Submitting:2
Failed to transfer wrapper log from PTMap-unmod-20090320-1433-oc8ufsv3/info/8 on SDSC_dtf_prews_pbs
Progress: Selecting site:8 Stage in:1 Submitting:1 Failed but can retry:1
Progress: Selecting site:8 Submitting:1 Submitted:1 Failed but can retry:1
Failed to transfer wrapper log from PTMap-unmod-20090320-1433-oc8ufsv3/info/9 on SDSC_dtf_prews_pbs
Progress: Selecting site:7 Stage in:1 Submitting:1 Failed but can retry:2
Progress: Selecting site:7 Submitting:1 Submitted:1 Failed but can retry:2
Failed to transfer wrapper log from PTMap-unmod-20090320-1433-oc8ufsv3/info/d on SDSC_dtf_prews_pbs
Progress: Selecting site:7 Submitted:1 Failed but can retry:3
Failed to transfer wrapper log from PTMap-unmod-20090320-1433-oc8ufsv3/info/b on SDSC_dtf_prews_pbs
Progress: Selecting site:7 Failed but can retry:4
Progress: Selecting site:6 Stage in:1 Failed but can retry:4
Progress: Selecting site:6 Submitting:1 Failed but can retry:4
Progress: Selecting site:6 Submitted:1 Failed but can retry:4
Failed to transfer wrapper log from PTMap-unmod-20090320-1433-oc8ufsv3/info/g on SDSC_dtf_prews_pbs
Progress: Selecting site:6 Failed but can retry:5
[yuechen at communicado PTMap]$ globus-job-run tg-login1.sdsc.teragrid.org /usr/bin/id
uid=502857(yuechen) gid=5195(anl100) groups=5195(anl100)
Sent: Fri 3/20/2009 1:14 PM
To: Yue, Chen - BMD
Cc: swift user
Subject: Re: [Swift-user] Teragrid execution problem
That is an error coming from the gridftp server.
Check that you van reliably (sveral times) use globus-url-copy to copy
files from the gridftp server that you specify in the sites file:
To: Yue, Chen - BMD
Cc: swift user
This email is intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged and confidential. If the reader of this email message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is prohibited. If you have received this email in error, please notify the sender and destroy/delete all copies of the transmittal. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090320/07af727f/attachment.html>
More information about the Swift-user
