[Swift-user] Problems in complex mapping situation
Michael Wilde
wilde at mcs.anl.gov
Fri Mar 20 14:37:15 CDT 2009
On 3/20/09 11:17 AM, Ben Clifford wrote:
> I've recreated this in a much smaller test case (pretty much whenever
> multidimensional arrays are used with ext (and probably other mappers)).
> I made what appeared to be an obvious fix but its causing some surprising
> behaviour in other tests so I haven't committed it. I'll keep playing
> though.
Great, that would be helpful.
I just tried the concurrent mapper on the real app, and its not going to
work as easily as I hoped. The underlying app code (the actual "oops"
executable in this case) is picky about the naming of output files: it
wants to see a path ending in something like proteinname.pdt (eg
T1af7.pdt), and will generate several other output files based on that:
pname.Energy, .lib, .rmsd etc.
The code is brittle and is getting a segfault, I think due to the
unexpected form of the output filename from the concurrent mapper.
I can try to deal with this in the shell script that wraps the app (or
the app itself), but the ext mapper solution would also be handy, if
thats close.
More information about the Swift-user
