[Swift-user] Swift/PBS Scheduler Slow to Report "Finished"?
Mihael Hategan
hategan at mcs.anl.gov
Thu Mar 19 17:41:49 CDT 2009
On Thu, 2009-03-19 at 17:35 -0500, Andrew Boyce wrote:
> I will definitely have to try that. Now I think I understand the
> benefits of that approach. Sending the data back is important.
> I do have a question though. In the Swift user guide, it states: "CoG
> coasters provide a low-overhead job submission and
> file transfer mechanism suited for the execution of short jobs (on the
> order of a few seconds) and the transfer of small files
> (on the order of a few kilobytes)."
> If I want to use coasters with longer jobs, with the transfer of large
> files, will that be a problem/be ill-suited with this approach?
> I know that our goal is to work with much, much larger files down the
> road, and much longer jobs.
You may not want to use the coaster file provider for large files, but
you could still use the coaster execution provider for running the jobs.
It should support larger jobs, but the benefit of using coasters for
such jobs may not be worth the extra layers of code (though there is
this specific case where coasters can help running multiple jobs per
node that has multiple cores/CPUs).
More information about the Swift-user
