[Swift-user] Does SWIFT_JOBDIR_PATH work for output?
Ben Clifford
benc at hawaga.org.uk
Mon Mar 16 13:27:02 CDT 2009
On Mon, 16 Mar 2009, Michael Wilde wrote:
> Testing locally on the bgp, I see that env passing works, and wrapper.sh picks
> up SWIFT_JOBDIR_PATH and does the right thing. So the problem seems to be
> somewhere in the Falkon path. We'll investigate, and can for the right jobdir
> handling in the meantime.
Try out the whole test suite while you are debugging that - if you find
other problems in there, you'll be less frustrated than when you find them
in your application later.
More information about the Swift-user
