[swift-user] List of OSG sites
Hodgess, Erin
HodgessE at uhd.edu
Fri Jun 26 15:43:48 CDT 2009
Hi again
Here's what's going on:
[erin at tp-login2 bin]$ pwd
/home/erin/swift-0.9/bin
[erin at tp-login2 bin]$ cat ~/.soft
# This is your SoftEnv configuration run control file.
# It is used to tell SoftEnv how to customize your environment by
# setting up variables such as PATH and MANPATH. To learn more
# about this file, do a "man softenv".
@python-2.5
+java-sun
+apache-ant
+gx-map
+condor
+gx-map
@globus-4
@default
+R
+torque
+maui
+matlab-7.7
+osg-client
#+osg-client-1.0.0-r1
@osg
+apache-ant
+gx-map
[erin at tp-login2 bin]$ source ~/.bashrc
[erin at tp-login2 bin]$ swift-osg-ress-site-catalog --engage-verified
-bash: swift-osg-ress-site-catalog: command not found
Erin M. Hodgess, PhD
Associate Professor
Department of Computer and Mathematical Sciences
University of Houston - Downtown
mailto: hodgesse at uhd.edu
-----Original Message-----
Sent: Fri 6/26/2009 3:39 PM
To: Hodgess, Erin
Cc: Michael Wilde; Melinda Chin; Swift User Discussion List
Subject: Re: [swift-user] List of OSG sites
did you remember to source bashrc or similar to resetup your path? resoft
destroys your custom path information. you need to have the swift bin
directory in your path to have this command work...
On Fri, Jun 26, 2009 at 3:33 PM, Hodgess, Erin <HodgessE at uhd.edu> wrote:
> This is getting weird:
> [erin at tp-login2 ~]$ swift-osg-ress-site-catalog --engage-verified
> Associate Professor
> From: hockyg at gmail.com on behalf of Glen Hocky
> Sent: Fri 6/26/2009 3:24 PM
> To: Hodgess, Erin
> It's likely this error can be fixed by the same thing Zhao did to get
> condor
> working last week (since the command works for me). Try putting @osg and
> +osg-client into your ~/.soft file and then resetting up by either logging
> back in or typing "resoft;source ~/.bashrc"
> for reference, here is my ~/.soft file
> @python-2.5
> +java-sun
> +osg-client
> +maui
> +torque
> +R
> +matlab-7.7
> +apache-ant
> +gx-map
> @osg
> @default
> @globus-4
> On Fri, Jun 26, 2009 at 3:20 PM, Hodgess, Erin <HodgessE at uhd.edu> wrote:
> > I'm having trouble with the swift-osg-ress-site-catalog command:
> > [erin at tp-login2 swift]$ swift-osg-ress-site-catalog --engage-verified
> > Neither the environment variable CONDOR_CONFIG,
> > /etc/condor/, nor ~condor/ contain a condor_config source.
> > Either set CONDOR_CONFIG to point to a valid config source,
> > or put a "condor_config" file in /etc/condor or ~condor/
> > Exiting.
> > <config>
> > </config>
> > Any help is much appreciated.
> > Thanks,
> > Erin
> > Associate Professor
> > From: swift-user-bounces at ci.uchicago.edu on behalf of Michael Wilde
> > Sent: Fri 6/26/2009 2:14 PM
> > To: Melinda Chin
> > Cc: Swift User Discussion List
> > From a practical point of view, you can get the sites in the OSG
> > "engagement" VO using this Swift command, which returns the list as a
> > sites.xml file:
> > That command also has options for getting sites from other VOs
> > swift-osg-ress-site-catalog --vo=osg
> > On 6/26/09 2:04 PM, Melinda Chin wrote:
> > > Here's what I think is a simple question but can't find the answer to?
> > > Where can I find a list of all the osg sites?
> > > Thank you,
> > > Melinda Chin
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090626/7c1055b8/attachment.html>
More information about the Swift-user
