[Swift-user] trouble with tutorial
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jun 16 16:47:16 CDT 2009
Erin,
The print() built-in procedure has been replaced by one called "trace()".
Replace print with trace in:
print("extract int value ", at extractint(a[v+1]));
- Mike
On 6/16/09 4:39 PM, Hodgess, Erin wrote:
> Hi all!
> This swift procedure doesn't seem to like the print statement(?)
> [erin at communicado swift1]$ swift -tc.file tc.data fold9.swift
> Could not start execution.
>         Compile error in procedure invocation at line 21: Procedure
> print is not declared.
> [erin at communicado swift1]$ cat fold9.swift
> type counterfile;
> (counterfile t) echo(string m) {
>   app {
>     echo m stdout=@filename(t);
> (counterfile t) countstep(counterfile i) {
>   app {
>     wcl @filename(i) @filename(t);
> counterfile a[]  <simple_mapper;prefix="foldout">;
> a[0] = echo("793578934574893");
>         iterate v {
>   a[v+1] = countstep(a[v]);
> } until (@extractint(a[v+1]) <= 1);
> [erin at communicado swift1]$ cat tc.data
> #NOTE WELL: fields in this file must be separated by tabs, not spaces
> #           and there must be no trailing whitespace at the end of each
> line.
> # sitename      app     pathname        (ignored)       (ignored)
> profiles
> localhost       echo    /bin/echo       INSTALLED       INTEL32::LINUX  null
> teraport        echo    /bin/echo       INSTALLED       INTEL32::LINUX  null
> localhost       translate       /usr/bin/tr     INSTALLED
> INTEL32::LINUX  null
> localhost       R       /home/erin/R-2.9.0/bin/R        INSTALLED
> INTEL32::LINUX  null
> localhost       wc      /usr/bin/wc     INSTALLED       INTEL32::LINUX  null
> localhost       convert /usr/bin/convert        INSTALLED
> INTEL32::LINUX  null
> localhost       wcl     /home/erin/swift1       INSTALLED
> INTEL32::LINUX  null
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
