[Swift-user] still having problems
Ben Clifford
benc at hawaga.org.uk
Mon Jun 15 11:57:11 CDT 2009
based on previous messages, its still unclear to me that you have the
program working outside of Swift.
Pretty much you need to be able to run rInvoke perm.short.R 0 from the
commandline successfully before attempting to run that command inside
Swift.
On Mon, 15 Jun 2009, Hodgess, Erin wrote:
> Hi again!
> I have brought things down to the bones here. Still no luck.
> The files are /home/erin/R-2.9.0/bin/perm.short.R and /home/erin/R-2.9.0/bin/perm4.swift
> [erin at tp-login2 bin]$ swift -tc.file tc.data perm4.swift
> Swift svn swift-r2950 cog-r2406
> RunID: 20090615-1137-nbfujhb2
> Progress:
> Progress: Checking status:1
> Progress: Stage in:1
> Execution failed:
> Exception in RInvoke:
> Arguments: [perm.short.R, 0]
> Host: localhost
> Directory: perm4-20090615-1137-nbfujhb2/jobs/v/RInvoke-vti60bcj
> stderr.txt:
> stdout.txt:
> Caused by:
> Exit code 1
> [erin at tp-login2 bin]$ cat perm4.swift
> type file{}
> (file procOut) permScript (file script, int batchSize){
> app{
> RInvoke @filename(script) batchSize ;
> int batchSize=0;
> file script<"perm.short.R">;
> file procOut<"a.txt">;
> procOut=permScript(script, batchSize);
> [erin at tp-login2 bin]$ cat perm.short.R
> # -- read data files that are hardcoded per analysis and get
> vox_speech_vec <- as.matrix(read.table("origccf.txt"))
> pm <- as.matrix(read.table("corr.perm.matrix.txt"))
> allinputs <- Sys.getenv("R_SWIFT_ARGS")
> print(allinputs)
> permlength <- as.numeric(noquote(strsplit(allinputs," ")[[1]][1]))
> # startrpermrow <- as.numeric(noquote(strsplit(allinputs," ")[[1]][1]))
> startrpermrow <- 1
> endpermrow <- permlength + startrpermrow
> debug = 1
> if (debug == 1) {
> print(paste("start", startrpermrow, "end", endpermrow, sep=","))
> # rotate across specified rows in permutation matrix
> for (rr in startrpermrow:endpermrow){
> permvec = pm[rr,]
> # initialize a 'ccf' matrix for each permutation
> ccf <- matrix(nrow=200, ncol=1)
> mat_row = 0
> for (vox in 1:200) {
> mat_row = mat_row + 1
> speechperm_ccf <- ccf(vox_speech_vec[vox,], permvec, lag.max = 6, type = c("correlation"), na.action=na.pass, plot = FALSE)
> if (any(speechperm_ccf$acf[1:13] == "NaN")) {
> # speechperm_ccf$acf[1:13] = 0
> speechperm_ccf$acf[1:13] <- rep(0,13)
> } else {
> speechperm_ccf$acf[1:13] = speechperm_ccf$acf[1:13]
> speechperm_ccf <- as.matrix(data.frame(speechperm_ccf$acf, speechperm_ccf$lag))[7:13,]
> speechperm_cor <- speechperm_ccf[which.max(speechperm_ccf[,1]),]
> ccf[mat_row, ] <- c(speechperm_cor[[1]])
> write.table (ccf, file=paste("a.txt",sep=""), row.names=FALSE, col.names=FALSE)
> if (debug == 1) {
> print(paste("permrow finished", rr, sep=","))
> print(date())
> rm(ccf)
> Any help appreciated.
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
More information about the Swift-user
