[Swift-user] Questions and ERRORs
Melinda Chin
me.melly at gmail.com
Mon Jun 15 11:43:01 CDT 2009
On Mon, Jun 15, 2009 at 11:41 AM, Melinda Chin <me.melly at gmail.com> wrote:
> I was trying to do the t.swift tutorial again and I keep getting stuck on
> this error. What does it mean to not be able to find a valid host? How do
> I remedy this? And another question on the side what's the difference
> between swift-user at ci.uchicago.edu and swift-user-owner at ci.uchicago.edu.
> For help we can send to both? or usually just swift-user?
> *THIS IS WHAT t.swift LOOKS LIKE:*
> [mchin at tp-login2 swift]$ cat t.swift
> type messagefile;
> (messagefile t) greeting (string s) {
> app{
> echo s stdout = @filename(t);
> (messagefile t) capitalise (messagefile f) {
> app {
> translate "[a-z]" "[A-Z]" stdin = @filename(f) stdout =
> @filename(t);
> messagefile outfile <"greeting.txt">;
> messagefile cfile <"capitalised.txt">;
> outfile = greeting("hello from Swift");
> cfile = capitalise(outfile);
> *THIS IS WHAT tc.data LOOKS LIKE:*
> [mchin at tp-login2 swift]$ cat tc.data
> #This is the transformation catalog.
> #It comes pre-configured with a number of simple transformations with
> #paths that are likely to work on a linux box. However, on some systems,
> #the paths to these executables will be different (for example, sometimes
> #some of these programs are found in /usr/bin rather than in /bin)
> #NOTE WELL: fields in this file must be separated by tabs, not spaces; and
> #there must be no trailing whitespace at the end of each line.
> # sitename transformation path INSTALLED platform profiles
> localhost echo /bin/echo INSTALLED
> INTEL32::LINUX null
> localhost cat /bin/cat INSTALLED
> INTEL32::LINUX null
> localhost ls /bin/ls INSTALLED
> INTEL32::LINUX null
> localhost grep /bin/grep INSTALLED
> INTEL32::LINUX null
> localhost sort /bin/sort INSTALLED
> INTEL32::LINUX null
> localhost paste /bin/paste INSTALLED
> INTEL32::LINUX null
> localhost translate /usr/bin/tr INSTALLED
> INTEL32::LINUX null
> *THIS IS THE ERROR MESSAGE:*
> [mchin at tp-login2 swift]$ swift t.swift
> Swift svn swift-r2950 cog-r2406
> RunID: 20090615-1125-6z1ehvf8
> Progress:
> Progress: Initializing site shared directory:1
> Execution failed:
> Could not find any valid host for task "Task(type=UNKNOWN,
> identity=urn:cog-1245083114852)" with constraints
> {filenames=[Ljava.lang.String;@1f0a76e, trfqn=translate,
> filecache=org.griphyn.vdl.karajan.lib.cache.CacheMapAdapter at 1f0a797,
> tr=translate}
> Thank you for your help,
> Melinda Chin
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090615/ab1e9db1/attachment.html>
More information about the Swift-user
