[Swift-user] upgraded to error one
Michael Wilde wilde at mcs.anl.gov
Sat Jun 13 14:58:27 CDT 2009
Erin, if the script never finishes, then thats something you and I
should work on outside of the swift-user list, as the problem is in your
R program, not in Swift. (Even if it came from the Swift apps CVS tree)
But when reporting things like this, additional info that is valuable
(as well as a few things to try) is:
- how long did you let it run?  Minutes? longer?
- did you look at the process using ps while it was running? Was it
consuming CPU time, or "frozen", waiting for something?
- what dataset was it reading? Is that dataset located through some
other means? Is the script reading from a file or a database? If a
database, can you get to it outside of R, eg with mysql?
How long is the dataset?  Did you try the program on a tiny fragment of
the data?
I did not look at the script - presumably the answers are in the source
code.
But unless Im missing something from earlier in this thread, this is a
topic we should work on off of the swift-user list. (and Im happy to
help with it)
- Mike
On 6/13/09 3:56 AM, Ben Clifford wrote:
> On Sat, 13 Jun 2009, Hodgess, Erin wrote:
>> It never finishes.
> Can you send the entire commandline you used?
> based on waht I see from your swiftscript it should be something like
> RPermInvoke permutations.R 4 1
More information about the Swift-user mailing list
