[Swift-user] upgraded to error one
Hodgess, Erin
HodgessE at uhd.edu
Sat Jun 13 02:08:14 CDT 2009
It never finishes.
Erin M. Hodgess, PhD
Associate Professor
Department of Computer and Mathematical Sciences
University of Houston - Downtown
mailto: hodgesse at uhd.edu
-----Original Message-----
Sent: Fri 6/12/2009 5:54 PM
To: Hodgess, Erin
Cc: swift-user at ci.uchicago.edu
Subject: Re: [Swift-user] upgraded to error one
if you run RPermInvoke.sh with appropriate commandline parameters and then
on the immediately following command line, type: echo $? what number do
you get?
On Fri, 12 Jun 2009, Hodgess, Erin wrote:
> I found some problems with RPermInvoke.sh, but still am having problems as you can see:
> [erin at tp-login2 bin]$ swift -tc.file tc.data perm1.swift
> Swift svn swift-r2950 cog-r2406
> RunID: 20090612-1714-qye382u3
> Progress:
> Progress: Checking status:1
> Execution failed:
> Exception in RPermInvoke:
> Arguments: [permutations.R, 4, 1]
> Host: localhost
> Directory: perm1-20090612-1714-qye382u3/jobs/7/RPermInvoke-7q5yf6cj
> stderr.txt:
> stdout.txt:
> Caused by:
> Exit code 1
> [erin at tp-login2 bin]$ cat tc.data
> #NOTE WELL: fields in this file must be separated by tabs, not spaces
> # and there must be no trailing whitespace at the end of each line.
> # sitename app pathname (ignored) (ignored) profiles
> localhost echo /bin/echo INSTALLED INTEL32::LINUX null
> teraport echo /bin/echo INSTALLED INTEL32::LINUX null
> localhost translate /usr/bin/tr INSTALLED INTEL32::LINUX null
> localhost R /home/erin/R-2.9.0/bin/R INSTALLED INTEL32::LINUX null
> localhost wc /usr/bin/wc INSTALLED INTEL32::LINUX null
> localhost convert /usr/bin/convert INSTALLED INTEL32::LINUX null
> localhost RInvoke /home/erin/R-2.9.0/bin/RInvoke.sh INSTALLED INTEL32::LINUX null
> teraport RInvoke /home/erin/R-2.9.0/bin/RInvoke.sh INSTALLED INTEL32::LINUX null
> localhost RPermInvoke /home/erin/R-2.9.0/bin/RPermInvoke.sh INSTALLED INTEL32::LINUX null
> [erin at tp-login2 bin]$ cat perm1.swift
> # for running the script permutations.R
> # swift will give R the permutation number
> # and the matrices for running the t-test
> # and will produce a file results/<permnumber><study>.out
> type file{}
> (file rout) perm_r (file scriptname, int pnum, int pstart)
> app
> RPermInvoke @filename(scriptname) pnum pstart ;
> file r_script<single_file_mapper; file="permutations.R">;
> #file perm_matrix<single_file_mapper; file="kiddata_NG-S.txt">;
> foreach i in [1:1]
> file r_out <single_file_mapper; file=@strcat("results/",i,".NG-S.out")>;
> (r_out) = perm_r(r_script,4,i);
> [erin at tp-login2 bin]$ cat RPermInvoke.sh
> #!/bin/bash
> export R_SCRIPT=$1
> shift
> export R_SWIFT_ARGS="$*"
> /home/erin/R-2.9.0/bin/R CMD BATCH --vanilla $R_SCRIPT
> Associate Professor
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090613/3a5c9b96/attachment.html>
More information about the Swift-user
