[Swift-user] upgraded to error one
Hodgess, Erin
HodgessE at uhd.edu
Fri Jun 12 17:18:10 CDT 2009
I found some problems with RPermInvoke.sh, but still am having problems as you can see:
[erin at tp-login2 bin]$ swift -tc.file tc.data perm1.swift
Swift svn swift-r2950 cog-r2406
RunID: 20090612-1714-qye382u3
Progress:
Progress: Checking status:1
Execution failed:
Exception in RPermInvoke:
Arguments: [permutations.R, 4, 1]
Host: localhost
Directory: perm1-20090612-1714-qye382u3/jobs/7/RPermInvoke-7q5yf6cj
stderr.txt:
stdout.txt:
Caused by:
Exit code 1
[erin at tp-login2 bin]$ cat tc.data
#NOTE WELL: fields in this file must be separated by tabs, not spaces
# and there must be no trailing whitespace at the end of each line.
# sitename app pathname (ignored) (ignored) profiles
localhost echo /bin/echo INSTALLED INTEL32::LINUX null
teraport echo /bin/echo INSTALLED INTEL32::LINUX null
localhost translate /usr/bin/tr INSTALLED INTEL32::LINUX null
localhost R /home/erin/R-2.9.0/bin/R INSTALLED INTEL32::LINUX null
localhost wc /usr/bin/wc INSTALLED INTEL32::LINUX null
localhost convert /usr/bin/convert INSTALLED INTEL32::LINUX null
localhost RInvoke /home/erin/R-2.9.0/bin/RInvoke.sh INSTALLED INTEL32::LINUX null
teraport RInvoke /home/erin/R-2.9.0/bin/RInvoke.sh INSTALLED INTEL32::LINUX null
localhost RPermInvoke /home/erin/R-2.9.0/bin/RPermInvoke.sh INSTALLED INTEL32::LINUX null
[erin at tp-login2 bin]$ cat perm1.swift
# for running the script permutations.R
# swift will give R the permutation number
# and the matrices for running the t-test
# and will produce a file results/<permnumber><study>.out
type file{}
(file rout) perm_r (file scriptname, int pnum, int pstart)
app
RPermInvoke @filename(scriptname) pnum pstart ;
file r_script<single_file_mapper; file="permutations.R">;
#file perm_matrix<single_file_mapper; file="kiddata_NG-S.txt">;
foreach i in [1:1]
file r_out <single_file_mapper; file=@strcat("results/",i,".NG-S.out")>;
(r_out) = perm_r(r_script,4,i);
[erin at tp-login2 bin]$ cat RPermInvoke.sh
#!/bin/bash
export R_SCRIPT=$1
shift
export R_SWIFT_ARGS="$*"
/home/erin/R-2.9.0/bin/R CMD BATCH --vanilla $R_SCRIPT
Erin M. Hodgess, PhD
Associate Professor
Department of Computer and Mathematical Sciences
University of Houston - Downtown
mailto: hodgesse at uhd.edu
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090612/dfd5aa4a/attachment.html>
More information about the Swift-user
