[Swift-user] Swift on local resources
Andriy Fedorov fedorov at cs.wm.edu
Fri Jun 12 15:46:15 CDT 2009
My ~/.ssh/auth.defaults is this:
george.bwh.harvard.edu.type=key
george.bwh.harvard.edu.username=fedorov
george.bwh.harvard.edu.key=/home/fedorov/.ssh/identity.pub
george.bwh.harvard.edu.passphrase=****
But what I am saying is that passphrase login is not working even when
I do plain ssh -- it is asking me to enter the password.
Here are the error messages I am getting trying to run a simple test:
Swift 0.9 swift-r2860 cog-r2388
RunID: 20090612-1643-tlksdhh5
Progress:
Progress:  Initializing site shared directory:1
Execution failed:
        Could not initialize shared directory on spl_george
Caused by:
        org.globus.cog.abstraction.impl.file.FileResourceException:
Error while communicating with the SSH server on
george.bwh.harvard.edu:22
Caused by:
        java.lang.NullPointerException
Caused by:
        at java.lang.StringBuffer.<init>(StringBuffer.java:104)
        at com.sshtools.j2ssh.openssh.PEMReader.read(PEMReader.java:117)
        at com.sshtools.j2ssh.openssh.PEMReader.<init>(PEMReader.java:61)
        at com.sshtools.j2ssh.openssh.OpenSSHPrivateKeyFormat.isFormatted(OpenSSHPrivateKeyFormat.java:205)
        at com.sshtools.j2ssh.transport.publickey.SshPrivateKeyFile.parse(SshPrivateKeyFile.java:132)
        at com.sshtools.j2ssh.transport.publickey.SshPrivateKeyFile.parse(SshPrivateKeyFile.java:171)
        at org.globus.cog.abstraction.impl.ssh.Ssh.connect(Ssh.java:254)
        at org.globus.cog.abstraction.impl.ssh.SSHConnectionBundle$Connection.ensureConnected(SSHConnectionBundle.java:234)
        at org.globus.cog.abstraction.impl.ssh.SSHConnectionBundle.allocateChannel(SSHConnectionBundle.java:76)
        at org.globus.cog.abstraction.impl.ssh.SSHChannelManager.getChannel(SSHChannelManager.java:71)
        at org.globus.cog.abstraction.impl.ssh.file.FileResourceImpl.start(FileResourceImpl.java:81)
        at org.globus.cog.abstraction.impl.file.FileResourceCache.getResource(FileResourceCache.java:98)
        at org.globus.cog.abstraction.impl.file.CachingDelegatedFileOperationHandler.getResource(CachingDelegatedFileOperationHandler.java:75)
        at org.globus.cog.abstraction.impl.file.CachingDelegatedFileOperationHandler.submit(CachingDelegatedFileOperationHandler.java:40)
        at org.globus.cog.abstraction.impl.common.task.CachingFileOperationTaskHandler.submit(CachingFileOperationTaskHandler.java:28)
        at org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:86)
        at edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
        at edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:166)
        at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
        at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
        at java.lang.Thread.run(Thread.java:595)
On Fri, Jun 12, 2009 at 4:17 PM, Andriy Fedorov<fedorov at cs.wm.edu> wrote:
> Allan,
> Thank you for the example.
> I have exactly same setup, but it doesn't work for me. I suspect the
> reason is that I am unable to set up my environment to work with
> passphrase. I can only log in with password. I wonder if there is any
> workaround...
> AF
> On Fri, Jun 12, 2009 at 4:04 PM, Allan
> Espinosa<aespinosa at cs.uchicago.edu> wrote:
>> Hi Andriy and Mike,
>> here is my example ~/.ssh/auth.defaults for executing jobs on
>> tp-login1.ci.uchicago.edu:
>> [aespinosa at tp-login2 ~]$ cat .ssh/auth.defaults
>> tp-login1.ci.uchicago.edu.type=key
>> tp-login1.ci.uchicago.edu.username=aespinosa
>> tp-login1.ci.uchicago.edu.key=/home/aespinosa/.ssh/id_dsa
>> tp-login1.ci.uchicago.edu.passphrase=XXXXXXXX
>> We have used falkon and coasters before for multi-core configurations.
>>  but for a single multi-core machine, i believe you can get away with
>> having multiple entries of the same host in the sites.xml file using
>> the ssh-provider.
>> ie:
>> <config>
>> <pool handle="CORE0">
>>   <execution provider="ssh"... />
>> </pool>
>> <pool handle="CORE1">
>> </pool>
>> </config>
>> 2009/6/12 Michael Wilde <wilde at mcs.anl.gov>:
>>> Ah, very cool. Im eager to get more user experience feedback on multicore
>>> use.
>>> So I will try to hunt down my examples of .ssh configs.
>>> Also, Allan Espinosa used this recently. Allan, can you post details and
>>> examples?
>>> Thanks!
>>> Mike
>>> On 6/12/09 2:06 PM, Andriy Fedorov wrote:
>>>> Michael,
>>>> Thank you for the advice, I will look into this. This is very helpful.
>>>> I had an impression Lava is not included in the list of schedulers
>>>> supported out of the box, but wanted to check.
>>>> Just a clarification -- I need to access two different types of local
>>>> resources. Cluster (via Lava or Condor) is one, but for the multicore
>>>> nodes we have on the network, which are not part of cluster, the only
>>>> option is to use ssh.
>>>> AF
>>>> On Fri, Jun 12, 2009 at 2:52 PM, Michael Wilde<wilde at mcs.anl.gov> wrote:
>>>>> Andriy,
>>>>> Ben or Mihael may have better ideas, but I offer my thoughts below.
>>>>> On 6/12/09 1:18 PM, Andriy Fedorov wrote:
>>>>>> Hi,
>>>>>> I am trying to set up Swift with the local cluster and non-cluster
>>>>>> resources in our lab. Here some configuration details.
>>>>>> Due to technical problems, passphrase login is not possible for the
>>>>>> nodes on local network, and I need to enter password each time.
>>>>>> For the cluster, I was able to set up passphrase login for the head
>>>>>> node. The cluster is running Lava and Condor schedulers at the same
>>>>>> time, but Lava should be used if possible.
>>>>>> Two questions:
>>>>>> (1) is it possible to configure Swift to talk to Lava scheduler?
>>>>> Making Swift talk to a new scheduler means writing a new CoG provider (in
>>>>> Java). You can likely use an existing "data" provider like "local"; you
>>>>> could model the "execution" provider after the "PBS" provider. How hard
>>>>> this
>>>>> is depends on how close Lava is to PBS in nature. (I dont know it). And
>>>>> the
>>>>> provider interface you need to code to is not well documented afaik.
>>>>> I would try the Condor provider. While that provider is less mature and
>>>>> tested than others, it should work, and if it doesnt, we should try to
>>>>> fix
>>>>> it.
>>>>> If possible, make sure a simple condor_submit hello-world works for you
>>>>> first.
>>>>> Run swift on the head/login node; use the "local" data provider.
>>>>> Another route is to use Falkon, but that will be harder and its less
>>>>> supported, so I suggest against this until easier routes are exhausted.
>>>>> I dont think that ssh will get you far, as to leverage the cluster I
>>>>> think
>>>>> you'd need to describe each worker node with a separate sites.xml entry.
>>>>> Thats fine in principle, but a bit awkward, and may have scheduling
>>>>> issues
>>>>> (ie if ssh hangs or dies when you dont own the node).
>>>>> Save ssh as another last resort; I suggest trying Condor first.
>>>>> If needed, people who used ssh recently can send you the info below.
>>>>> - Mike
>>>>>> (2) I am following the instructions on setting up ssh site provider to
>>>>>> use nodes on the local network.
>>>>>>  (2.1) do I need to set up auth.defaults even if I have ssh-agent
>>>>>> running, and can ssh to the remote node without being asked for
>>>>>> password?
>>>>>>  (2.2.) can anybody give me more detailed instructions on how to set
>>>>>> up auth.defaults? I cannot make it work.
>>>>>> Thanks
>>>>>> Andriy Fedorov
>>>>>> _______________________________________________
>> Allan M. Espinosa <http://allan.88-mph.net/blog>
>> PhD student, Computer Science
>> University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
More information about the Swift-user mailing list
