[Swift-user] Swift on local resources
Andriy Fedorov
fedorov at cs.wm.edu
Fri Jun 12 15:17:02 CDT 2009
Allan,
Thank you for the example.
I have exactly same setup, but it doesn't work for me. I suspect the
reason is that I am unable to set up my environment to work with
passphrase. I can only log in with password. I wonder if there is any
workaround...
AF
On Fri, Jun 12, 2009 at 4:04 PM, Allan
Espinosa<aespinosa at cs.uchicago.edu> wrote:
> Hi Andriy and Mike,
> here is my example ~/.ssh/auth.defaults for executing jobs on
> tp-login1.ci.uchicago.edu:
> [aespinosa at tp-login2 ~]$ cat .ssh/auth.defaults
> tp-login1.ci.uchicago.edu.type=key
> tp-login1.ci.uchicago.edu.username=aespinosa
> tp-login1.ci.uchicago.edu.key=/home/aespinosa/.ssh/id_dsa
> tp-login1.ci.uchicago.edu.passphrase=XXXXXXXX
> We have used falkon and coasters before for multi-core configurations.
> but for a single multi-core machine, i believe you can get away with
> having multiple entries of the same host in the sites.xml file using
> the ssh-provider.
> ie:
> <config>
> <pool handle="CORE0">
> <execution provider="ssh"... />
> </pool>
> <pool handle="CORE1">
> </pool>
> </config>
> 2009/6/12 Michael Wilde <wilde at mcs.anl.gov>:
>> Ah, very cool. Im eager to get more user experience feedback on multicore
>> use.
>> So I will try to hunt down my examples of .ssh configs.
>> Also, Allan Espinosa used this recently. Allan, can you post details and
>> examples?
>> Thanks!
>> Mike
>> On 6/12/09 2:06 PM, Andriy Fedorov wrote:
>>> Michael,
>>> Thank you for the advice, I will look into this. This is very helpful.
>>> I had an impression Lava is not included in the list of schedulers
>>> supported out of the box, but wanted to check.
>>> Just a clarification -- I need to access two different types of local
>>> resources. Cluster (via Lava or Condor) is one, but for the multicore
>>> nodes we have on the network, which are not part of cluster, the only
>>> option is to use ssh.
>>> AF
>>> On Fri, Jun 12, 2009 at 2:52 PM, Michael Wilde<wilde at mcs.anl.gov> wrote:
>>>> Andriy,
>>>> Ben or Mihael may have better ideas, but I offer my thoughts below.
>>>> On 6/12/09 1:18 PM, Andriy Fedorov wrote:
>>>>> Hi,
>>>>> I am trying to set up Swift with the local cluster and non-cluster
>>>>> resources in our lab. Here some configuration details.
>>>>> Due to technical problems, passphrase login is not possible for the
>>>>> nodes on local network, and I need to enter password each time.
>>>>> For the cluster, I was able to set up passphrase login for the head
>>>>> node. The cluster is running Lava and Condor schedulers at the same
>>>>> time, but Lava should be used if possible.
>>>>> Two questions:
>>>>> (1) is it possible to configure Swift to talk to Lava scheduler?
>>>> Making Swift talk to a new scheduler means writing a new CoG provider (in
>>>> Java). You can likely use an existing "data" provider like "local"; you
>>>> could model the "execution" provider after the "PBS" provider. How hard
>>>> this
>>>> is depends on how close Lava is to PBS in nature. (I dont know it). And
>>>> the
>>>> provider interface you need to code to is not well documented afaik.
>>>> I would try the Condor provider. While that provider is less mature and
>>>> tested than others, it should work, and if it doesnt, we should try to
>>>> fix
>>>> it.
>>>> If possible, make sure a simple condor_submit hello-world works for you
>>>> first.
>>>> Run swift on the head/login node; use the "local" data provider.
>>>> Another route is to use Falkon, but that will be harder and its less
>>>> supported, so I suggest against this until easier routes are exhausted.
>>>> I dont think that ssh will get you far, as to leverage the cluster I
>>>> think
>>>> you'd need to describe each worker node with a separate sites.xml entry.
>>>> Thats fine in principle, but a bit awkward, and may have scheduling
>>>> issues
>>>> (ie if ssh hangs or dies when you dont own the node).
>>>> Save ssh as another last resort; I suggest trying Condor first.
>>>> If needed, people who used ssh recently can send you the info below.
>>>> - Mike
>>>>> (2) I am following the instructions on setting up ssh site provider to
>>>>> use nodes on the local network.
>>>>> (2.1) do I need to set up auth.defaults even if I have ssh-agent
>>>>> running, and can ssh to the remote node without being asked for
>>>>> password?
>>>>> (2.2.) can anybody give me more detailed instructions on how to set
>>>>> up auth.defaults? I cannot make it work.
>>>>> Thanks
>>>>> Andriy Fedorov
>>>>> _______________________________________________
> Allan M. Espinosa <http://allan.88-mph.net/blog>
> PhD student, Computer Science
> University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
More information about the Swift-user
