[Swift-user] weird "non output" from swift procedure
Michael Wilde
wilde at mcs.anl.gov
Wed Jun 10 14:20:24 CDT 2009
Erin, I suspect that since you did not specify any mappings, that *if*
the script ran correctly, it produced output files under the directory
_concurrent.
This "concurrent" mapper and its directory convention are the default
when no output mapping is specified, and is described in the user guide.
Can you check is the expected output files (which will have weird names)
is under that directory? (Do an "ls -lRt" on it).
- Mike
On 6/10/09 1:59 PM, Hodgess, Erin wrote:
> Hi again!
> This runs without errors, but it does not produce any output.
> Is it missing some file names, please?
> Thanks,
> Erin
> [erin at tp-login2 ~]$ swift -tc.file tc.data restart.swift
> Swift svn swift-r2950 cog-r2406
> RunID: 20090610-1355-ccu7emi4
> Progress:
> Progress: Checking status:1 Finished successfully:3
> Final status: Finished successfully:4
> [erin at tp-login2 ~]$ cat restart.swift
> type file;
> (file f) touch() {
> app {
> touch @f;
> (file f) processL(file inp) {
> app {
> echo "processL" stdout=@f;
> (file f) processR(file inp) {
> app {
> broken "process" stdout=@f;
> (file f) join(file left, file right) {
> app {
> echo "join" @left @right stdout=@f;
> file f = touch();
> file g = processL(f);
> file h = processR(f);
> file i = join(g,h);
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
