[Swift-user] Writing to an output file
Hodgess, Erin HodgessE at uhd.edu
Thu Jun 4 16:35:44 CDT 2009
I talked to Mike, got things fixed, and all is well.
thank you,
Sincerely,
Erin
Erin M. Hodgess, PhD
Associate Professor
Department of Computer and Mathematical Sciences
University of Houston - Downtown
mailto: hodgesse at uhd.edu
-----Original Message-----
From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
Sent: Thu 6/4/2009 4:34 PM
To: Hodgess, Erin
Cc: swift-user at ci.uchicago.edu
Subject: Re: [Swift-user] Writing to an output file
For most practical purposes, there are no side-effects in swift. "int x
= 0" means "For convenience, and for the current lexical scope, x will
be 0". It's the common (though reversed) "statement, where x = 0" from
math, except there is no "statement" in your case.
Outside of "initialCondition" it doesn't mean anything. I'm not sure
what exactly the compiler is complaining about, but what you wrote
doesn't mean much.
That plus what Mike said in his reply to this message.
May I suggest expressing in simple words what you are trying to achieve?
>From that, it's easier to both translate to swift and for us to help
with that.
Mihael
On Thu, 2009-06-04 at 12:36 -0500, Hodgess, Erin wrote:
> Here is what SHOULD be a simple process.  I'm writing to an array, and
> sending that to an output file.  Here are the files and the results:
> [erin at tp-login2 swift1]$ cat iter2.swift
> type file;
> app initialCondition() {
>         int x = 10;
>      int step[0]=initialCondition();
> file o <"output.txt">;
>         o=step[0];
> [erin at tp-login2 swift1]$ swift -tc.file tc.data iter2.swift
> Could not compile SwiftScript source: line 4:13: unexpected token: x
> The file is in /home/erin/swift1/iter2.swift.
> Thanks,
> Erin
> Associate Professor
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090604/fb7d59b4/attachment.html>
More information about the Swift-user mailing list
