[Swift-user] Writing to an output file
Michael Wilde
wilde at mcs.anl.gov
Thu Jun 4 13:06:16 CDT 2009
Erin,
An app function can only be the declaration of a single external
application. It can't be anything else - and here you're trying to use
an app declaration to return a value, like a Java property.
You'll typically want to place statements like "int x = 10" in open code
(ie outside all otehr procedures, typically at the end of your script)
or inside a compound procedure.
Next, what you're trying to do here doesnt fit well with the Swift
model: you typically dont take data that you compute directly in Swift
(as opposed to in a Swift app) and write that data to a file. Files are
typically written only by app procedures - i.e., they contain the output
of programs.
- Mike
In this test, were you just trying to fill an array with scalar values
On 6/4/09 12:36 PM, Hodgess, Erin wrote:
> Here is what SHOULD be a simple process. I'm writing to an array, and
> sending that to an output file. Here are the files and the results:
> [erin at tp-login2 swift1]$ cat iter2.swift
> type file;
> app initialCondition() {
> int x = 10;
> int step[0]=initialCondition();
> file o <"output.txt">;
> o=step[0];
> [erin at tp-login2 swift1]$ swift -tc.file tc.data iter2.swift
> Could not compile SwiftScript source: line 4:13: unexpected token: x
> The file is in /home/erin/swift1/iter2.swift.
> Thanks,
> Erin
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
