[Swift-user] (no subject)
Zhao Zhang zhaozhang at uchicago.edu
Wed Jun 3 14:51:54 CDT 2009
Hi, Mike
I am helping Erin on this, it seems we figure the problem out, and we
are testing the script further.
zhao
Michael Wilde wrote:
> Also, I should clarify: the message:
> "Compile error in procedure invocation at line 11: Wrong type for
> parameter number 0, expected file, got file[]"
> is really referring to the expression in the assignment statement
> *within* the foreach.
> Its complaining that you passed an object of data type "file[]" -
> i.e., "array of file" to a procedure whose corresponding argument was
> declared as expecting an object of data type "file" - i.e., a single
> scalar object of type "file".
> The ability to pass an entire file[] array is a cool feature of Swift,
> but not what you wanted to do in this case.
> - Mike
> On 6/3/09 2:40 PM, Michael Wilde wrote:
>> (Erin, please use good subject lines when sending to the list, as it
>> makes it easier to manage and find discussion threads)
>> The line:
>> foreach ix in frame {
>>    output[ix] = rotate(frame, 180);  output[ix] = rotate(frame, 180);
>> should be:
>> foreach ix,i in frame {
>>   output[i] = rotate(ix, 180);
>> or the inner statement can be:
>>  output[i] = rotate(frame[i], 180);
>> Not sure, but you might be able to use simple_mapper for input
>> mapping as well. I'll leave you to experiment with that aspect for now.
>> - Mike
>> On 6/3/09 2:11 PM, Hodgess, Erin wrote:
>>> Hi Swift Users:
>>> I'm trying to collect all of the files with the extension ".jpg",
>>> rotate them 180 degrees, and produce output of "hoot.xxx.jpeg".
>>> here is my swift file and my error message.  I've tried lots of
>>> things with files and foreach, but I can't make any sense out of this.
>>> Any suggestions, please?
>>> [erin at tp-login2 swift1]$ cat rot2.swift
>>> type file;
>>> app (file o) rotate(file s, int angle) {
>>>    convert "-rotate" angle @filename(s) @filename(o);
>>> file  frame[] <filesys_mapper; pattern="*.jpg">;
>>> file output[] <simple_mapper;suffix=".jpeg",prefix="hoot.">;
>>> }  [erin at tp-login2 swift1]$
>>> [erin at tp-login2 swift1]$ swift -tc.file tc.data rot2.swift
>>> Could not start execution.
>>>         Compile error in foreach statement at line 10: Compile error
>>> in procedure invocation at line 11: Wrong type for parameter number
>>> Thanks,
>>> Erin
>>> Erin M. Hodgess, PhD
>>> Associate Professor
>>> Department of Computer and Mathematical Sciences
>>> University of Houston - Downtown
>>> mailto: hodgesse at uhd.edu
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
