[Swift-user] (no subject)
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Jun  3 14:40:22 CDT 2009
(Erin, please use good subject lines when sending to the list, as it
makes it easier to manage and find discussion threads)
The line:
foreach ix in frame {
    output[ix] = rotate(frame, 180);  output[ix] = rotate(frame, 180);
should be:
foreach ix,i in frame {
   output[i] = rotate(ix, 180);
or the inner statement can be:
  output[i] = rotate(frame[i], 180);
Not sure, but you might be able to use simple_mapper for input mapping
as well. I'll leave you to experiment with that aspect for now.
- Mike
On 6/3/09 2:11 PM, Hodgess, Erin wrote:
> Hi Swift Users:
> I'm trying to collect all of the files with the extension ".jpg", rotate
> them 180 degrees, and produce output of "hoot.xxx.jpeg".
> here is my swift file and my error message.  I've tried lots of things
> with files and foreach, but I can't make any sense out of this.
> Any suggestions, please?
> [erin at tp-login2 swift1]$ cat rot2.swift
> type file;
> app (file o) rotate(file s, int angle) {
>    convert "-rotate" angle @filename(s) @filename(o);
> file  frame[] <filesys_mapper; pattern="*.jpg">;
> file output[] <simple_mapper;suffix=".jpeg",prefix="hoot.">;
> }  [erin at tp-login2 swift1]$
> [erin at tp-login2 swift1]$ swift -tc.file tc.data rot2.swift
> Could not start execution.
>         Compile error in foreach statement at line 10: Compile error in
> procedure invocation at line 11: Wrong type for parameter number 0,
> expected file, got file[]
> Thanks,
> Erin
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
