[Swift-user] [swift-plot-log]
Ben Clifford
benc at hawaga.org.uk
Wed Jul 15 09:14:44 CDT 2009
looks like the generation dependencies are not correctly defined in
swift-plot-log but that usually this does not cause a problem. I will have
a poke around and see if it is easy to fix.
On Mon, 13 Jul 2009, Melinda Chin wrote:
> On Mon, Jul 13, 2009 at 3:03 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
> > Can you paste about 10 lines or so before this message:
> cat execute2.transitions | sed 's/[^ ]* *[^ ]* \([^ ]*\).*/\1/' | sort |
> uniq > execute2.seenstates
> trail execute2
> info-and-karajan-actives
> grep: /*-info: No such file or directory
> (standard_in) 1: syntax error
> Warning: empty y range [1:1], adjusting to [0.99:1.01]
> kickstarts-to-event > kickstart.event
> execution-summaries > execution-counts.txt
> table-jobs-sites > jobs-sites.html
> per-site-execute2-durations > site-duration.txt
> cat execute2.transitions | swap-and-sort |last-transition-line >
> execute2.last
> cat execute2.last | sed 's/^\([^ ]*\) \([^ ]*\) \([^ ]*\)\(.*\)/\3/' | sort
> | uniq -c > execute2.lastsummary
> cat execute.transitions | swap-and-sort |last-transition-line >
> execute.last
> cat execute.last | sed 's/^\([^ ]*\) \([^ ]*\) \([^ ]*\)\(.*\)/\3/' | sort |
> uniq -c > execute.lastsummary
> cat execute2.event | cut -f 5 -d ' ' | sort | uniq -c | sort | sed 's/^
> *\(.*\) .*$/\1/' | uniq -c > jobs.retrycount.summary
> cat execute.event | cut -f 5 -d ' ' | sort | uniq -c > trname-summary
> m4 -I/opt/swift/r3003/bin/../libexec/log-processing/
> /opt/swift/r3003/bin/../libexec/log-processing//index.html.template >
> index.html
> /opt/swift/r3003/bin/../libexec/log-processing//execute2.html.template >
> execute2.html
> /opt/swift/r3003/bin/../libexec/log-processing//execute.html.template >
> execute.html
> /opt/swift/r3003/bin/../libexec/log-processing//karajan.html.template >
> karajan.html
> /opt/swift/r3003/bin/../libexec/log-processing//info.html.template >
> info.html
> /opt/swift/r3003/bin/../libexec/log-processing//assorted.html.template >
> assorted.html
> /opt/swift/r3003/bin/../libexec/log-processing//kickstart.html.template >
> kickstart.html
> m4:/opt/swift/r3003/bin/../libexec/log-processing//kickstart.html.template:23:
> cannot open `kickstart.stats': No such file or directory
> > make: *** [kickstart.html] Error 1
> > What is the commandline that you typed to generate this?
> * swift-plot-log radial_norefine-20090713-1120-mt712ud7.log*
> > Melinda Chin
More information about the Swift-user
