struct of structs via ext mapper(was Re: [Swift-user] single structs for ext mapper.)
Allan Espinosa
aespinosa at cs.uchicago.edu
Tue Jul 14 17:13:03 CDT 2009
i see. so this mean that in my will need to generate this made-up file
too right? the swift -dryrun works. will test it out with the real
run now.
thanks,
-Allan
2009/7/14 Ben Clifford <benc at hawaga.org.uk>:
> looks like its trying to map a path for the out structure itself, which
> probably shouldn't be happening.
> as a workaround you might try adding a made-up filename for out itself,
> in addition to the members of out. no idea if that will work or not but
> worth a try.
Allan M. Espinosa <http://allan.88-mph.net/blog>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
More information about the Swift-user
