[Swift-user] [swift-plot-log]
Melinda Chin
me.melly at gmail.com
Mon Jul 13 15:08:22 CDT 2009
On Mon, Jul 13, 2009 at 3:03 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
> Can you paste about 10 lines or so before this message:
cat execute2.transitions | sed 's/[^ ]* *[^ ]* \([^ ]*\).*/\1/' | sort |
uniq > execute2.seenstates
trail execute2
info-and-karajan-actives
grep: /*-info: No such file or directory
(standard_in) 1: syntax error
Warning: empty y range [1:1], adjusting to [0.99:1.01]
kickstarts-to-event > kickstart.event
execution-summaries > execution-counts.txt
table-jobs-sites > jobs-sites.html
per-site-execute2-durations > site-duration.txt
cat execute2.transitions | swap-and-sort |last-transition-line >
execute2.last
cat execute2.last | sed 's/^\([^ ]*\) \([^ ]*\) \([^ ]*\)\(.*\)/\3/' | sort
| uniq -c > execute2.lastsummary
cat execute.transitions | swap-and-sort |last-transition-line >
execute.last
cat execute.last | sed 's/^\([^ ]*\) \([^ ]*\) \([^ ]*\)\(.*\)/\3/' | sort |
uniq -c > execute.lastsummary
cat execute2.event | cut -f 5 -d ' ' | sort | uniq -c | sort | sed 's/^
*\(.*\) .*$/\1/' | uniq -c > jobs.retrycount.summary
cat execute.event | cut -f 5 -d ' ' | sort | uniq -c > trname-summary
m4 -I/opt/swift/r3003/bin/../libexec/log-processing/
/opt/swift/r3003/bin/../libexec/log-processing//index.html.template >
index.html
/opt/swift/r3003/bin/../libexec/log-processing//execute2.html.template >
execute2.html
/opt/swift/r3003/bin/../libexec/log-processing//execute.html.template >
execute.html
/opt/swift/r3003/bin/../libexec/log-processing//karajan.html.template >
karajan.html
/opt/swift/r3003/bin/../libexec/log-processing//info.html.template >
info.html
/opt/swift/r3003/bin/../libexec/log-processing//assorted.html.template >
assorted.html
/opt/swift/r3003/bin/../libexec/log-processing//kickstart.html.template >
kickstart.html
m4:/opt/swift/r3003/bin/../libexec/log-processing//kickstart.html.template:23:
cannot open `kickstart.stats': No such file or directory
> make: *** [kickstart.html] Error 1
> What is the commandline that you typed to generate this?
* swift-plot-log radial_norefine-20090713-1120-mt712ud7.log*
> Melinda Chin
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090713/a0446b10/attachment.html>
More information about the Swift-user
