[Swift-user] condor on communicado problem
Allan Espinosa aespinosa at cs.uchicago.edu
Mon Jul 6 14:38:47 CDT 2009
do you have +osg-client or @osg in your ~/.soft file?
2009/7/6 Hodgess, Erin <HodgessE at uhd.edu>:
> I tried the following:
> [erin at communicado ~]$  voms-proxy-init
> -bash: voms-proxy-init: command not found
> But this is not working either.
> Thanks,
> Erin
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> -----Original Message-----
> From: yecartes at gmail.com on behalf of Allan Espinosa
> Sent: Mon 7/6/2009 2:16 PM
> To: Hodgess, Erin
> Cc: swift-user at ci.uchicago.edu
> Subject: Re: [Swift-user] condor on communicado problem
> Hi Erin,
> under what VO is your proxy when you accessed the resource?  each VO
> runs under a different userspace so you can't access Engage user
> directories if the vo with you current proxy is not using engage.
> to make sure you get the right VO, you can use voms-proxy-init
> -Allan
>> Hi again, Swift People:
>> I'm on communicado, trying to run swift via condor (instead of gram).
>> I generated my sites file and selected one location.
>> Here is my output:
>> [erin at communicado swift1]$ swift -tc.file tc.test.data -sites.file
>> sites1k.xml wc1a.swift
>> Swift svn swift-r2998 (swift modified locally) cog-r2427
>> RunID: 20090706-1334-iq5phkm6
>> Progress:
>> Progress:  Selecting site:13  Initializing site shared directory:2
>> Progress:  Selecting site:10  Initializing site shared directory:5
>> Progress:  Selecting site:9  Initializing site shared directory:6
>> Progress:  Selecting site:8  Initializing site shared directory:7
>> Progress:  Selecting site:7  Initializing site shared directory:8
>> Progress:  Selecting site:6  Initializing site shared directory:9
>> Progress:  Selecting site:5  Initializing site shared directory:10
>> Progress:  Selecting site:4  Initializing site shared directory:11
>> Progress:  Selecting site:3  Initializing site shared directory:12
>> Progress:  Selecting site:2  Initializing site shared directory:13
>> Progress:  Initializing site shared directory:15
>> Execution failed:
>>         Could not initialize shared directory on
>> Clemson-ciTeam_osgce.cs.clemson.edu
>> Caused by:
>>         org.globus.cog.abstraction.impl.file.FileResourceException: Cannot
>> create directory /export/osg/data/engage/tmp
>> Caused by:
>>         Server refused performing the request. Custom message: Server
>> refused creating directory (error code 1) [Nested exception message:
>> Custom
>> message: Unexpected reply: 500-Command failed :
>> globus_gridftp_server_file.c:globus_l_gfs_file_mkdir:554:
>> 500-System error in mkdir: Permission denied
>> 500-A system call failed: Permission denied
>> 500 End.]
>> This was using all of the values from the sites file.
>> The directory that the sites file has is not present.
>> Does anyone have any suggestions, please?
>> Thanks in advance,
>> Erin
>> Associate Professor
Allan M. Espinosa <http://allan.88-mph.net/blog>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
More information about the Swift-user mailing list
