[Swift-user] problem with swift-osg-ress-catalog function
Ben Clifford benc at hawaga.org.uk
Mon Jul 6 12:50:31 CDT 2009
Most likely you do not have a recent enough version of
swift-osg-ress-site-catalog - you will need a source build of swift of at
least r2984, as that option has not been in any Swift release yet.
On Mon, 6 Jul 2009, Hodgess, Erin wrote:
> Hi Swift People:
> I just tried the swift-osg-ress-site-catalog command with the condor-g option, but I get the following errors:
> [erin at communicado ~]$ swift-osg-ress-site-catalog --condor-g
> Unknown option: c
> Usage:
>     swift-osg-ress-site-catalog [options]
> Options:
>     --help  Show this help message
>     --vo=[name]
>             Set what VO to query ReSS for
>     --engage-verified
>             Only retrieve sites verified by the Engagement VO site
>             verification tests This can not be used together with --vo, as
>             the query will only work for sites advertising support for the
>             Engagement VO.
>             This option means information will be retrieved from the
>             Engagement collector instead of the top-level ReSS collector.
>     --out=[filename]
>             Write to [filename] instead of stdout
> The Swift user guide indicates that the condor-g is indeed an option, but actual use here indicates that it is not an option.
> Any help much appreciated.
> Sincerely,
> Erin
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
More information about the Swift-user mailing list
