[Swift-user] Problem with running swift and condor
Michael Wilde wilde at mcs.anl.gov
Thu Jul 2 21:16:05 CDT 2009
Erin, Im not sure where "parameter not supported" is coming from, but
check if this is a problem:
your pool element for clemson says /home/osg for its work directory, but
for clemson-ciTeam in the RESS output I see:
     <workdirectory
 >/export/osg/data/engage/tmp/Clemson-ciTeam</workdirectory>
Unless you know /home/osg to be a good value for that site, I would try
the value above.
- Mike
On 7/2/09 9:04 PM, Hodgess, Erin wrote:
> Hello all.
> I am running swift on communicado.
> In the sites file, I am referring to an OSG site to be run on condor
> rather than gram.
> Here is the sites file:
> <config>
>   <!-- Clemson-ciTeam -->
>   <pool handle="Clemson-ciTeam" >
>     <gridftp  url="gsiftp://osgce.cs.clemson.edu/" />
>     <jobmanager universe="vanilla"
> url="osgce.cs.clemson.edu:2119/jobmanager-condor" major="2" />
>  <execution provider="condor" />
>  <profile namespace="globus" key="jobType">grid</profile>
>  <profile namespace="globus" key="gridResource">gt2
> osgce.cs.clemson.edu/jobmanager-condor</profile>
>     <workdirectory >/home/osg</workdirectory>
>   </pool>
> </config>
> The swift program is very simple; running a word count on a file:
> [erin at communicado swift1]$ cat wc1a.swift
> type file;
> app (file o) count(file i) {
>   wc @i stdout=@o;
> file i <"input.txt">;
> foreach j in [1:15]
> file o <single_file_mapper;file=@strcat("results/",j,".out")>;
>         (o)=count(i);
> But when I run the swift job, I get a "parameter not supported".  Note:
> this job works fine on localhost, teraport, and on several OSG sites
> when set up using gram.
> [erin at communicado swift1]$ swift -tc.file tc.test.data -sites.file
> sites1i.xml wc1a.swift
> Swift svn swift-r2950 cog-r2406
> RunID: 20090702-2009-sk2d7m89
> Progress:
> Progress:  Selecting site:13  Initializing site shared directory:1
> Stage in:1
> Progress:  Selecting site:13  Submitting:1  Submitted:1
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/8
> on Clemson-ciTeam
> Progress:  Selecting site:12  Stage in:1 Failed but can retry:2
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/9
> on Clemson-ciTeam
> Progress:  Selecting site:12  Submitted:1 Failed but can retry:2
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/b
> on Clemson-ciTeam
> Progress:  Selecting site:11  Stage in:1 Failed but can retry:3
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/e
> on Clemson-ciTeam
> Progress:  Selecting site:11 Failed but can retry:4
> Progress:  Selecting site:10  Stage in:1 Failed but can retry:4
> Progress:  Selecting site:10  Submitted:1 Failed but can retry:4
> Progress:  Selecting site:10 Failed but can retry:5
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/g
> on Clemson-ciTeam
> Progress:  Selecting site:9  Stage in:1 Failed but can retry:5
> Progress:  Selecting site:9  Submitted:1 Failed but can retry:5
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/i
> on Clemson-ciTeam
> Progress:  Selecting site:9 Failed but can retry:6
> Progress:  Selecting site:8  Stage in:1 Failed but can retry:6
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/k
> on Clemson-ciTeam
> Progress:  Selecting site:8 Failed but can retry:7
> Progress:  Selecting site:7  Stage in:1 Failed but can retry:7
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/m
> on Clemson-ciTeam
> Progress:  Selecting site:7 Failed but can retry:8
> Progress:  Selecting site:6  Stage in:1 Failed but can retry:8
> Progress:  Selecting site:6  Submitted:1 Failed but can retry:8
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/o
> on Clemson-ciTeam
> Progress:  Selecting site:6 Failed but can retry:9
> Progress:  Selecting site:5  Stage in:1 Failed but can retry:9
> Progress:  Selecting site:5  Submitted:1 Failed but can retry:9
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/q
> on Clemson-ciTeam
> Progress:  Selecting site:5 Failed but can retry:10
> Progress:  Selecting site:4  Stage in:1 Failed but can retry:10
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/s
> on Clemson-ciTeam
> Progress:  Selecting site:4 Failed but can retry:11
> Progress:  Selecting site:3  Stage in:1 Failed but can retry:11
> Progress:  Selecting site:3  Submitted:1 Failed but can retry:11
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/u
> on Clemson-ciTeam
> Progress:  Selecting site:3 Failed but can retry:12
> Progress:  Selecting site:2  Stage in:1 Failed but can retry:12
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/x
> on Clemson-ciTeam
> Progress:  Selecting site:2 Failed but can retry:13
> Progress:  Selecting site:1  Stage in:1 Failed but can retry:13
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/z
> on Clemson-ciTeam
> Progress:  Selecting site:1 Failed but can retry:14
> Progress:  Stage in:1 Failed but can retry:14
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/1
> on Clemson-ciTeam
> Progress: Failed but can retry:15
> Progress:  Submitted:1 Failed but can retry:14
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/3
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/5
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/7
> on Clemson-ciTeam
> on Clemson-ciTeam
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/d
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/f
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/h
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/j
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/l
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/n
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/p
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/r
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/t
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/v
> on Clemson-ciTeam
> Failed to transfer wrapper log from wc1a-20090702-2009-sk2d7m89/info/y
> on Clemson-ciTeam
> Progress:  Failed:1 Failed but can retry:14
> Execution failed:
>         Exception in wc:
> Arguments: [input.txt]
> Host: Clemson-ciTeam
> Directory: wc1a-20090702-2009-sk2d7m89/jobs/y/wc-y2zfj4dj
> stderr.txt:
> stdout.txt:
> Caused by:
>         Cannot submit job
> Caused by:
>         Parameter not supported
> Thank you for your kind attention.
> Erin
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
