[Swift-user] condor on communicado
Hodgess, Erin
HodgessE at uhd.edu
Thu Jul 2 12:39:00 CDT 2009
Is there a condor pool on communicado, please?
This is what I get:
[erin at communicado ~]$ condor_q
Error:
Extra Info: You probably saw this error because the condor_schedd is not
running on the machine you are trying to query. If the condor_schedd is not
running, the Condor system will not be able to find an address and port to
connect to and satisfy this request. Please make sure the Condor daemons are
running and try again.
Extra Info: If the condor_schedd is running on the machine you are trying to
query and you still see the error, the most likely cause is that you have
setup a personal Condor, you have not defined SCHEDD_NAME in your
condor_config file, and something is wrong with your SCHEDD_ADDRESS_FILE
setting. You must define either or both of those settings in your config
file, or you must use the -name option to condor_q. Please see the Condor
manual for details on SCHEDD_NAME and SCHEDD_ADDRESS_FILE.
Here is my .soft file:
[erin at communicado ~]$ cat .soft
# This is your SoftEnv configuration run control file.
# It is used to tell SoftEnv how to customize your environment by
# setting up variables such as PATH and MANPATH. To learn more
# about this file, do a "man softenv".
@python-2.5
+java-sun @swift
+apache-ant
+gx-map
+condor
+gx-map
@globus-4
+R
+torque
+maui
+matlab-7.7
+osg-client
#+osg-client-1.0.0-r1
@osg
+apache-ant
+gx-map
@default
Erin M. Hodgess, PhD
Associate Professor
Department of Computer and Mathematical Sciences
University of Houston - Downtown
mailto: hodgesse at uhd.edu
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090702/69538f4d/attachment.html>
More information about the Swift-user
